| generalization [message #49498] |
Sun, 17 September 2006 18:28  |
Hi.
Having created simple gmf editor for UML.ecore i've got trouble
setting generalizations. For two classes A and B where A extends B my
editor generates following uml2 file
<uml:Package xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML">
<packagedElement xsi:type="uml:Class" name="A">
<generalization general="#//B"/>
</packagedElement>
<packagedElement xsi:type="uml:Class" name="B"/>
</uml:Package>
And then UML Model editor fails to open it with this exception:
org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '//B'. (platform:/resource/test1/test1.uml, 4, 37)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1001)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1066)
From the perspective of my editor this looks like generalization is lost
when diagram is being closed/opened.
Domain meta information properties of the corresponding Link mapping in my
gmfmap file are:
Containment feauture: EReference generalization
Element: EClass Generalization
Source Feature: not set
Target Feature: EReference general
Any help is highly appreciated as well as some explanation of what all
those Source/Target Features and their values
(general/source/target/specific, etc.) are.
wbr, eugen.
| Re: generalization [message #50374 is a reply to message #49826] |
Mon, 18 September 2006 17:08   |
Thank you for your answers. But i still can't find 'Invariant
Prefix' property anywhere to get sources generated properly... could you
please give some more hints where to look for it?
wbr,eugen.
В письме Mon, 18 Sep 2006 08:13:49 -0400, Kenn Hussey
написал:
> Eugen,
> I looks like your editor is using the wrong resource implementation to
> serialize your model - the resource implemenation in UML2 makes use of
> UUIDs, but it appears that your resource does not.
> Kenn
> "Бушуев" <jnbu@yahoo.com> wrote in message
> news:pan.2006.09.17.22.28.04.201811@yahoo.com...
>> Hi.
>> <?xml version="1.0" encoding="UTF-8"?>
>> </packagedElement>
>> </uml:Package>
>> at
>> at
>> gmfmap file are:
>> wbr, eugen.
| Re: generalization [message #50876 is a reply to message #50374] |
Tue, 19 September 2006 07:56  |
Originally posted by: khussey.ca.ibm.com
Eugen,
The 'Invariant Prefix' generator model property will only be available for
UML2 generator models, i.e. models for which you have taken advantage of
some of the UML2-specific options when importing your UML model. One way to
ensure this it to press the 'Process All' button in the importer.
Once you have a UML2 generator model, the property will show up in the
Properties view when you have the generator model (root) element selected.
Kenn
FUDForum. Page generated in 0.03086 seconds
