Home » Eclipse Projects » SWTBot » support for JUnit4?
support for JUnit4? [message #4328] Thu, 06 November 2008 17:32 Go to next message
I noticed in the users guide at
http://swtbot.sourceforge.net/users-guide.html that there is a mention
to "Ensure that you're using JUnit 3".
Is there any planned support for JUnit 4? Or maybe that is already built
in and that statement was made only so that the example runs correctly?
Joe Luebker
Re: support for JUnit4? [message #4398 is a reply to message #4328] Thu, 06 November 2008 22:04 Go to previous message
Technically you can still use JUnit 4 to write and run your tests, for
both plain SWT and RCP/plugins.
The problem arises if you'd like to run pde based SWTBot tests from the
command line via the eclipse test framework. More info on this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153429
-- Ketan
> Joe Luebker
Previous Topic:Changes in SWTBot license from Apache License 2.0 to EPL
Next Topic:test of my SWT application
Current Time: Tue Jul 22 15:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.03082 seconds
