Home » Archived » BIRT » bean parameter error
bean parameter error [message #49479] Wed, 22 June 2005 11:51 Go to next message
Originally posted by: tony.xxxxxxxxxxxx.com
Hi. I am installing the birt viewer on tomcat. when i try to run the
report on tomcat it has an error. The error is:
javax.servlet.ServletException: bean parameterBean not found within scope.
Does anybody know how to fix it. Thanks ahead of time for the help
Re: bean parameter error [message #49774 is a reply to message #49479] Wed, 22 June 2005 15:09 Go to previous message
Tony,
You probably already tried old viewer versions. "ParameterBean" is used in
one of the milestone releases before 1.0 and replaced by other classes in
the final 1.0 release.
I assume you have a brand new viewer installation without mixed with old
version. The error you see probably is caused by those cached old
generated jsp related java and class files. You can simply go to:
"Tomcat home/work/standalone/localhost/birt/" and remove everything.
Let us know if there are still problems.
Jun Zhai
Previous Topic:Open Report -NoCalssDefFoundError
Next Topic:http status 500 error
Current Time: Sun Jun 22 03:30:30 EDT 2025
Powered by FUDForum. Page generated in 0.03343 seconds
