Home » Eclipse Projects » Plugin Development Environment (PDE) » Export Wizard fails
Export Wizard fails [message #49410] Thu, 05 March 2009 08:31 Go to next message
on a rather fresh install of Eclipse 3.4.2 the Export Wizard fails
consistently.
I get a dialog box: Error - Reason: problems during export
and the detail message is this:
Problems during export
C:\dev\eclipse-3.4.2\workspace\.metadata\.plugins\org.eclips e.pde.core\temp\org.eclipse.pde.container.feature\assemble.o rg.eclipse.pde.container.feature.win32.win32.x86.xml:80:
required attribute propertyName not set
I get this error even with the SampleView plugin.
Does anyone have an idea what might cause this behaviour?
Thanks.
Christian
Re: Export Wizard fails [message #49530 is a reply to message #49410] Thu, 05 March 2009 18:13 Go to previous messageGo to next message
Christian Schmitt wrote:
> consistently.
Do you get anymore information from the log file that is produced by the
export operation? What's your target platform set in Eclipse 3.4.2? Are
you exporting just a plug-in or a product maybe?
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Export Wizard fails [message #49588 is a reply to message #49530] Fri, 06 March 2009 02:20 Go to previous message
>> consistently.
C:deveclipse-3.4.2workspace.metadata.pluginsorg.eclipse.pde. coretemporg.eclipse.pde.container.featureassemble.org.eclips e.pde.container.feature.win32.win32.x86.xml:80:
I'm trying to export a plug-in. Where would I find that log file?
The folder mentioned in the error message is empty after the failed export.
But there is some good news. After switching to a new (empty) workspace and
importing the plugi-in project the export works? Oh well....
Thanks.
Christian
Re: Export Wizard fails [message #592874 is a reply to message #49410] Thu, 05 March 2009 18:13 Go to previous message
> consistently.
Re: Export Wizard fails [message #592900 is a reply to message #49530] Fri, 06 March 2009 02:20 Go to previous message
>> consistently.
Thanks.
Christian
Previous Topic:Problem getting all files/folders when unpack="true"
Next Topic:PreferenceStore and AbstractPreferenceInitializer
Current Time: Sun Jul 13 21:40:36 EDT 2025
Powered by FUDForum. Page generated in 0.47949 seconds
