Home » Newcomers » Newcomers » class not found exception
class not found exception [message #49388] Fri, 08 April 2005 12:27 Go to next message
Originally posted by: email2dhiraj.yahoo.com
I have the connector/j drivers for MYSQL. I added the CLASSPATH vars in
Eclipse BUILD PATH. it knows where to find the jar files, but I get
ClassNotFound Exception when I try to establish a connection to the
DB?STAND ALONE PROGRAM IS WORKING.problem when plugin is used.on eclipse
2.0 it is working .but not on eclipse 3.0.2. What am I overlooking?
Re: class not found exception [message #49448 is a reply to message #49388] Fri, 08 April 2005 15:13 Go to previous messageGo to next message
Originally posted by: ask.me.com
Hi, I have similar issue and I see three other threads with this problem
(no clear answers in any of them). I don't understand exactly how the
folder structure should look. My Eclipse Distilled book is ok but when I
do as it says to add custom user libaries I still get the error that it
can't find my custom java jar files or documents even though I can browse
them from within Eclipse.
Any help would be appreciated.
Re: class not found exception [message #49538 is a reply to message #49448] Fri, 08 April 2005 17:25 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"JT" <ask@me.com> wrote in message
news:d89789f09616831b921e9d01dd404b3b$1@www.eclipse.org...
The issues are different, depending on whether you're writing a plugin or an
application. If you're writing an Eclipse plugin, the compile-time
classpath (that is, the classpath that you're editing when you add
libraries) is not used at run time. The runtime classpath is strictly
determined by the plugin's dependencies on other plugins, and the classes
exported by those other plugins.
In other words, if you want to load a class from inside a plugin, the class
must be exported by another plugin that your plugin depends on. (Or, you
must use your own classloader; but if that class then loads other classes,
it may or may not succeed.)
Maybe someone has written a plugin that wraps the MySQL drivers? If so,
that's what you need.
Don't shoot me, I'm only the messenger...
-Walter Harley
BEA Systems, Inc.
Re: class not found exception [message #49870 is a reply to message #49538] Sat, 09 April 2005 13:49 Go to previous messageGo to next message
then , what to do. i mean how to make dependent plugin to export the
needed jar flies.
Re: class not found exception [message #50895 is a reply to message #49870] Mon, 11 April 2005 20:19 Go to previous message
"dhiraj kumar" <email2dhiraj@yahoo.com> wrote in message
news:b6d07b6d7e1ed1c31068fed988c20fae$1@www.eclipse.org...
> needed jar flies.
There are a couple of books on how to write plugins for Eclipse. Some were
mentioned in this newsgroup just recently; see the thread <"developing
plugins for eclipse 3.x" book recommendation>.
It is not something that can be easily summarized in a newsgroup posting,
unfortunately.
Previous Topic:part of an import statement not resolved
Next Topic:can't open a java file!!!!!
Current Time: Fri Nov 07 14:49:13 EST 2025
Powered by FUDForum. Page generated in 0.09151 seconds
