Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling an IPlatformRunnable
Profiling an IPlatformRunnable [message #49369] Fri, 06 January 2006 06:07 Go to next message
I'm trying to profile an Eclipse Application but cannot get any Execution
Statistics. here is my set up
1. Have a class which implements IPlatformRunnable, it displays a shell
with a couple of menu items. The code I want to profile is triggered when
I select the appropriate menu item.
2. I have TPTP 4.1 install and correctly configured i.e. profiling a Java
Application works fine.
3. I created a run configuration for my Eclipse Application and have
tested it works as expected.
4. When I launch that configuration using profiling, the application
launches fine.
5. When I open the Execution Statistics I get the message "No data is
available for display".
Any ideas on what I have done wrong?
thanks
Mark
Re: Profiling an IPlatformRunnable [message #49429 is a reply to message #49369] Fri, 06 January 2006 09:52 Go to previous message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 00519B16852570EE_=
Content-Type: text/plain; charset="US-ASCII"
Click on the Profile button -> Select 'Profile...' -> Select your launch
configuration on the left -> Select the Profiling tab -> Click on Add to
add a new profiling set -> Next -> Select 'Execution Time Analysis' under
'Time Analysis' -> If you also want graphical information, you'll need to
select 'Execution Time Analysis' and select the 'Show execution flow
graphical details' radio button -> Click on finish -> Click on Profile.
You should now get the execution statistics.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Click on the Profile button -&gt; Select
'Profile...' -&gt; Select your launch configuration on the left -&gt; Select
the Profiling tab -&gt; Click on Add to add a new profiling set -&gt; Next
-&gt; Select 'Execution Time Analysis' under 'Time Analysis' -&gt; If you
also want graphical information, you'll need to select 'Execution Time
Analysis' and select the 'Show execution flow graphical details' radio
button -&gt; Click on finish -&gt; Click on Profile. &nbsp;You should now
get the execution statistics.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 00519B16852570EE_=--
Previous Topic:Starting the Agent Controller make my JBoss crash
Next Topic:New Technology Agent Controller - Migration Sample
Current Time: Thu Nov 06 06:56:31 EST 2025
Powered by FUDForum. Page generated in 0.03003 seconds
