Home » Archived » Visual Editor (VE) » VE Bean JLabel generates another code as JCheckBox
VE Bean JLabel generates another code as JCheckBox [message #49343] Mon, 12 July 2004 09:02 Go to next message
Originally posted by: khw.warnkoenig.de
Hi all outside,
I try a little with VE and it loocks verry nice. But one Problem I has. If I
do the example from the document "Build GUIs with the Eclipse Visual Editor"
then I get another code for the JLabel Bean. There is no variable generated
like the JCheckBox. Instead the code and the variable is generated inside
the private member getJContendPane(); Then the next step, change the text
from this label
Re: VE Bean JLabel generates another code as JCheckBox [message #49373 is a reply to message #49343] Mon, 12 July 2004 11:25 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
That was an improvement we tried to make. Over 90% of the time JLabel's
don't need their text to be changed once created, so we just made them
local. However, some people do need to change the label later, but we
had no way to "promote" the JLabel to be a variable. So just last week
we changed it so that JLabels won't have a get method, but they will
have a variable that can be accessed to change. This has not got into a
build yet.
Thanks, Rich Kulp
Re: VE Bean JLabel generates another code as JCheckBox [message #49551 is a reply to message #49343] Tue, 13 July 2004 07:09 Go to previous messageGo to next message
The workaround I use, is to manually create the field by hand.
I change this:
class MyWindow {
void getMyPanel() {
JLabel myLabel = new JLabel();
to:
class MyWindow {
JLabel myLabel
void getMyPanel() {
K-H Warnkönig wrote:
> Hi all outside,
> from this labelŽfrom theactionPerformed() jLabel.setText("kjhjh") faild,
> because its unknown there.
> Where can I chane this behavior or what did Iwrong
> Thanks a lot
> Karl-Heinz
> ________________________
> Warnkönig Elektronik
> Karl-Heinz Warnkönig
> Im Weinberg 3
> 88709 Meersburg
> tel. 07532 5432
> fax. 07532 2484
Re: VE Bean JLabel generates another code as JCheckBox [message #49729 is a reply to message #49373] Tue, 13 July 2004 11:12 Go to previous messageGo to next message
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> schrieb im Newsbeitrag
news:ccuaea$fhu$4@eclipse.org...
> build yet.
> Thanks, Rich Kulp
Hi Rich!
If you will provide an accessible variable for JLabels, why not simply
provide a get method uniformly like for other components?
Thanks.
Youjun Luo
Sulzer GmbH
Frankfurter Ring 162
80807 Munich
Germany
Re: VE Bean JLabel generates another code as JCheckBox [message #49759 is a reply to message #49729] Tue, 13 July 2004 11:43 Go to previous message
Because that is extra overhead for a label when most people don't even
need the variable. Very few people actually even need it as a separate
variable.
> Hi Rich!
> Thanks.
> Youjun Luo
> Sulzer GmbH
> 80807 Munich
> Germany
Thanks, Rich Kulp
Re: VE Bean JLabel generates another code as JCheckBox [message #594943 is a reply to message #49343] Mon, 12 July 2004 11:25 Go to previous message
build yet.
Thanks, Rich Kulp
Re: VE Bean JLabel generates another code as JCheckBox [message #595008 is a reply to message #49343] Tue, 13 July 2004 07:09 Go to previous message
I change this:
class MyWindow {
void getMyPanel() {
to:
class MyWindow {
JLabel myLabel
void getMyPanel() {
> Hi all outside,
> Thanks a lot
> Karl-Heinz
> Im Weinberg 3
> 88709 Meersburg
> tel. 07532 5432
> fax. 07532 2484
Re: VE Bean JLabel generates another code as JCheckBox [message #595067 is a reply to message #49373] Tue, 13 July 2004 11:12 Go to previous message
> build yet.
> Thanks, Rich Kulp
Hi Rich!
Thanks.
Youjun Luo
Sulzer GmbH
80807 Munich
Germany
Re: VE Bean JLabel generates another code as JCheckBox [message #595077 is a reply to message #49729] Tue, 13 July 2004 11:43 Go to previous message
variable.
> Hi Rich!
> Thanks.
> Youjun Luo
> Sulzer GmbH
> 80807 Munich
> Germany
Thanks, Rich Kulp
Previous Topic:VE I20040712 and SWT Linux ?
Next Topic:properties can be set but not shown after reload Visual Editor
Current Time: Thu Jul 17 14:27:45 EDT 2025
Powered by FUDForum. Page generated in 0.09996 seconds
