Home » Archived » Visual Editor (VE) » VE Swing Problem: BoxLayout can't be shared
VE Swing Problem: BoxLayout can't be shared [message #49268] Sat, 10 July 2004 14:13 Go to next message
Hi!
I am somewhat new to swing and have a small problem with VE, which btw is an
awesome product!
I create a new visual swing class (JFrame) with the default content pane
attached to the frame. This pane uses BoxLayout.X_AXIS.
Now I want to place two jPanels on the content pane (jPanelLeft and
jPanelRight).
Wenn i try to set the Layout of the new panels to BoxLayout.Y_Axis, i get
the following error:
"components: java.awt.AWTError (BoxLayout can't be shared)"
I use Eclipse 3.0 with VE-SDK-S20040628/VE-runtime-S20040628. All setting
were done using VE.
Do you have any hints for me how i can solve this problem?
best regards,
florian
Re: VE Swing Problem: BoxLayout can't be shared [message #49286 is a reply to message #49268] Sat, 10 July 2004 14:43 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
I was able to reproduce this. It is a bug. Please go to bugzilla and
open a bug against VE against component JFC/Swing. That way we can track
it and fix it.
Thanks, Rich Kulp
Re: VE Swing Problem: BoxLayout can't be shared [message #49297 is a reply to message #49286] Sat, 10 July 2004 15:39 Go to previous messageGo to next message
Done.
florian
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> schrieb im Newsbeitrag
news:ccpdal$62e$1@eclipse.org...
> it and fix it.
> Thanks, Rich Kulp
Re: VE Swing Problem: BoxLayout can't be shared [message #49876 is a reply to message #49297] Tue, 13 July 2004 15:13 Go to previous messageGo to next message
What bug # did you open? I can't find any new bugs on bugzilla under VE
for this.
Florian Sachs wrote:
> Done.
> Best regards,
> florian
>>it and fix it.
>>Thanks, Rich Kulp
Thanks, Rich Kulp
Re: VE Swing Problem: BoxLayout can't be shared [message #50384 is a reply to message #49876] Thu, 15 July 2004 09:32 Go to previous message
Bug 69785 https://bugs.eclipse.org/bugs/show_bug.cgi?id=69785 was opened but
their is already one open for this problem... bug 61870
https://bugs.eclipse.org/bugs/show_bug.cgi?id=61870
Regards...
Peter Walker
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cd1c5l$p0n$1@eclipse.org...
> for this.
> > Done.
> > Best regards,
> > florian
> >>it and fix it.
> >>Thanks, Rich Kulp
> Thanks, Rich Kulp
Re: VE Swing Problem: BoxLayout can't be shared [message #594902 is a reply to message #49268] Sat, 10 July 2004 14:43 Go to previous message
it and fix it.
Thanks, Rich Kulp
Re: VE Swing Problem: BoxLayout can't be shared [message #594905 is a reply to message #49286] Sat, 10 July 2004 15:39 Go to previous message
Done.
florian
> it and fix it.
> Thanks, Rich Kulp
Re: VE Swing Problem: BoxLayout can't be shared [message #595117 is a reply to message #49297] Tue, 13 July 2004 15:13 Go to previous message
for this.
> Done.
> Best regards,
> florian
>>it and fix it.
>>Thanks, Rich Kulp
Thanks, Rich Kulp
Re: VE Swing Problem: BoxLayout can't be shared [message #595291 is a reply to message #49876] Thu, 15 July 2004 09:32 Go to previous message
Regards...
Peter Walker
> for this.
> > Done.
> > Best regards,
> > florian
> >>it and fix it.
> >>Thanks, Rich Kulp
> Thanks, Rich Kulp
Previous Topic:Change default properties
Next Topic:How to use the VE SDK
Current Time: Mon Nov 03 04:39:00 EST 2025
Powered by FUDForum. Page generated in 0.06374 seconds
