| context test suite and classpath [message #49238] |
Fri, 23 May 2008 08:14  |
Originally posted by: pereza.gsicommerce.com
Hi all,
When Mylyn creates its context test suite it's missing various
parameters from the classpath (thinks like loading the mock jar, etc).
These are necessary for the tests to run correctly. The context tests
cannot run successfully without this.
Is there a way to somehow set up these additions to the classpath ahead
of time? So that the auto-created tests have the correct path?
tia,
arturo
| Re: context test suite and classpath [message #50221 is a reply to message #49238] |
Tue, 17 June 2008 12:51  |
You should be able to set the classpath in the same way as you set it
for normal unit test launch configurations (e.g. via the Arguments tab).
If that's not working or not sufficient please file a new bug.
Mik
Arturo Perez wrote:
> Hi all,
> tia,
> arturo
| Re: context test suite and classpath [message #590127 is a reply to message #49238] |
Mik
Arturo Perez wrote:
> Hi all,
> tia,
> arturo
FUDForum. Page generated in 0.04562 seconds
