Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem with pluginPath (headless build)
Problem with pluginPath (headless build) [message #49223] Wed, 04 March 2009 12:55 Go to next message
Originally posted by: birt.lewold.at
I have a very strange problem:
I have multiple plugins. To keep it simple assume PluginA depends on PluginB
Because of various reasons I don't want to build them in the same buildDirectory. (main
reason is, that two running headless builds conflict with each other if they use the same
buildDirectory).
So I build them in separate build directories and copy the resulting plugins into
/MyBuildResults/plugins
in build.properties i specify
pluginPath=/MyBuildResults
When building PluginB it seems to find PluginA (during "generateScript" it checks for
missing plugins, and PluginA is not listed there .... if I delete PluginA it gets listed).
But .... I get "the import cannot be resolved" ERRORs for all my classes in PluginA.
If I would build everything in the same plugin directory things work correct.
Can anyone out there enlighten me what I am doing wrong?
Chris
Re: Problem with pluginPath (headless build) [message #49232 is a reply to message #49223] Thu, 05 March 2009 02:35 Go to previous messageGo to next message
First of all I want to correct a simple thing:
Of course I meant that PluginB depends on PluginA.
I found out some otherr thing ....
This does not work .....
/MyBuildResults/plugins/PluginA_1.1.0.20080303.jar
If I unpack the plugin so that it looks like
/MyBuildResults/plugins/PluginA_1.1.0.20080303 (folder containing the JARs contents)
Then everything works as expected.
Please please someone tell me I am doing something severely wrong.
Why does pluginPath not pick up plugin JAR files ??????
Chris
> PluginB
> buildDirectory. (main reason is, that two running headless builds
> conflict with each other if they use the same buildDirectory).
> plugins into
> it checks for missing plugins, and PluginA is not listed there .... if I
> in PluginA.
> correct.
> Chris
Re: Problem with pluginPath (headless build) [message #49351 is a reply to message #49223] Thu, 05 March 2009 04:36 Go to previous messageGo to next message
May be you can have a look at the generated build.xml file for the plug-in
B which doesn't compile. Mainly you should check the @dot target in charge
of compiling the plug-in, check the classpath attribute here to be sure
that A is there ...
Manu
Re: Problem with pluginPath (headless build) [message #49381 is a reply to message #49351] Thu, 05 March 2009 06:20 Go to previous messageGo to next message
I checked that ... PluginA is contained in the classpath.
I think I figured out the source of the problem .....
PluginA is a plugin wrapping a "plain old java JAR file" and exporting the classes
contained there (using the Runime page in the Manifest editor).
It seems that the eclipse build process is not able to resolve such types of plugins.
Chris
Manuel Selva wrote:
> plug-in B which doesn't compile. Mainly you should check the @dot target
> in charge of compiling the plug-in, check the classpath attribute here
> to be sure that A is there ...
> Manu
Re: Problem with pluginPath (headless build) [message #50081 is a reply to message #49381] Tue, 10 March 2009 15:25 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=157375
The problem is basically that the java compiler can't compile against
nested jars. So they will need to be extracted first.
PDE/Build doesn't (yet) do this extraction automatically.
-Andrew
> the classes contained there (using the Runime page in the Manifest editor).
> types of plugins.
> Chris
> Manuel Selva wrote:
>> target in charge of compiling the plug-in, check the classpath
>> attribute here to be sure that A is there ...
>> Manu
Re: Problem with pluginPath (headless build) [message #592769 is a reply to message #49223] Thu, 05 March 2009 02:35 Go to previous message
Chris
> PluginB
> plugins into
> in PluginA.
> correct.
> Chris
Re: Problem with pluginPath (headless build) [message #592794 is a reply to message #49223] Thu, 05 March 2009 04:36 Go to previous message
that A is there ...
Manu
Re: Problem with pluginPath (headless build) [message #592808 is a reply to message #49351] Thu, 05 March 2009 06:20 Go to previous message
Chris
Manuel Selva wrote:
> Manu
Re: Problem with pluginPath (headless build) [message #593093 is a reply to message #49381] Tue, 10 March 2009 15:25 Go to previous message
-Andrew
> types of plugins.
> Chris
> Manuel Selva wrote:
>> Manu
Previous Topic:Versioning on dependent features?
Next Topic:headless p2 director application
Current Time: Tue Jul 15 11:00:18 EDT 2025
Powered by FUDForum. Page generated in 0.10352 seconds
