Home » Eclipse Projects » Nebula » [grid] Menu popup in void
[grid] Menu popup in void [message #49185] Fri, 08 February 2008 21:11 Go to next message
I've got a context driven menu popup happening when a user right-clicks
a row in the grid. This is working fine.
Unfortunately, when the user right-clicks in a non-populated row (at the
bottom) I still get a menuDetected event when nothing is selected. As
such, the context code is wrong. I could detect this non-selection and
not display the menu, but in the case where a clicks a row first,
selecting it, and then right clicks into a void I'd prefer to still not
show a menu as it might be unclear that the menu selection relates to a
row selected much higher.
Does anyone know the correct way to determine a right-click in this void
area that would result in a menuDetected event - so that I can safely
ignore this event and not show a menu.
Re: [grid] Menu popup in void [message #49207 is a reply to message #49185] Mon, 11 February 2008 17:04 Go to previous messageGo to next message
Is this question more suited to another newsgroup? platform.swt?
Grant Slender wrote:
Re: [grid] Menu popup in void [message #49972 is a reply to message #49207] Wed, 27 February 2008 10:18 Go to previous message
Hi Grant,
You should be able to use the x,y coordinates of the menu detect event
and ask Grid.getItem(x,y). If it returns null then you can assume its
not over a row.
regards,
-Chris
>> right-clicks a row in the grid. This is working fine.
>> the bottom) I still get a menuDetected event when nothing is selected.
>> As such, the context code is wrong. I could detect this non-selection
>> and not display the menu, but in the case where a clicks a row first,
>> not show a menu as it might be unclear that the menu selection relates
>> to a row selected much higher.
>> void area that would result in a menuDetected event - so that I can
>> safely ignore this event and not show a menu.
Re: [grid] Menu popup in void [message #588542 is a reply to message #49185] Mon, 11 February 2008 17:04 Go to previous message
Re: [grid] Menu popup in void [message #588769 is a reply to message #49207] Wed, 27 February 2008 10:18 Go to previous message
Hi Grant,
not over a row.
regards,
-Chris
Previous Topic:ToolTip widget is not getting disposed properly on Grid Table
Next Topic:Auto-resize a column?
Current Time: Sat Jul 26 01:48:29 EDT 2025
Powered by FUDForum. Page generated in 0.05348 seconds
