Home » Archived » Visual Editor (VE) » loading large amount of data into jTable
loading large amount of data into jTable [message #49120] Fri, 09 July 2004 10:48 Go to next message
Originally posted by: lim.hock-chai.arch.com
I've two questions regarding loading large amount of data to jTable:
Currently, I load the data into a Vector. The Vector is then passed to a
class that extend AbstractTableModel. This works well, however, I encounter
the following two problem:
1) When user's request result in a large amount of data, the program
receives java.lang.OutOfMemoryError. What is the typical way of handle this
in jTable?
2) I would like to display the table to the user as the data is being
loaded, much like open a large Excel spreadsheet, user is able to scroll
down as the data continue to load.
thanks
Note (Please let me know if I'm not supposed to post this type of question
to this list. )
Re: loading large amount of data into jTable [message #49149 is a reply to message #49120] Fri, 09 July 2004 10:54 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
This is for the VE and not for java usages questions.
Sorry, Rich Kulp
Re: loading large amount of data into jTable [message #49241 is a reply to message #49120] Fri, 09 July 2004 12:41 Go to previous messageGo to next message
I'd recommend posting this question in the forums of the Java Desktop
community: http://community.java.net/javadesktop/
- Jeff
> in jTable?
> thanks
> to this list. )
Re: loading large amount of data into jTable [message #49256 is a reply to message #49120] Sat, 10 July 2004 04:38 Go to previous message
Hock-Chai,
This is not a list about Swing... but I think I can help you.
If your data comes from a database, try to subclass AbstractTableModel
and
use for example
" connection.createStatement(ResultSet.TYPE_SCROLL_INSENSITIVE ,
ResultSet.CONCUR_READ_ONLY)". If you have problems, send me a mail and
I'll send you a table model based on an scrollable cursor. The gain is a
600 % over
the Vector approach. DefaultTableModel is not a very good solution even
for few records. Try to use a model based, for example, in ArrayLists. The
gain over DefaultTableModel is aprox a 20 %.
And please, don't use this list to ask other than VE.
Francesc
> in jTable?
> thanks
> to this list. )
Re: loading large amount of data into jTable [message #594855 is a reply to message #49120] Fri, 09 July 2004 10:54 Go to previous message
Sorry, Rich Kulp
Re: loading large amount of data into jTable [message #594865 is a reply to message #49120] Fri, 09 July 2004 12:41 Go to previous message
- Jeff
> in jTable?
> thanks
> to this list. )
Re: loading large amount of data into jTable [message #594884 is a reply to message #49120] Sat, 10 July 2004 04:38 Go to previous message
Hock-Chai,
and
use for example
600 % over
Francesc
> in jTable?
> thanks
> to this list. )
Previous Topic:Is there any Scedule for VE Built Release 1.0?
Next Topic:VE Swing Problem: BoxLayout can't be shared
Current Time: Fri Jun 27 20:31:44 EDT 2025
Powered by FUDForum. Page generated in 0.04733 seconds
