Home » Archived » OHF » Requesting correction of the original document
Requesting correction of the original document [message #49068] Fri, 10 October 2008 13:00 Go to next message
Hello OHF community,
I need to post CDA wrapped text document which will contain request to
correct other (original) document. Is it possible to set id of the
original document into metadata using OHF bridge?
Dmitry
Re: Requesting correction of the original document [message #49128 is a reply to message #49068] Fri, 10 October 2008 17:23 Go to previous messageGo to next message
Hi Dmitry,
I believe what you are asking for is replacement option on the XDS
Source. There is a parameter on the submission called
"documentEntryParentDocumentId". When this is set to the entry uuid of
the 'old' document a replacment transaction is invoked. Note you need to
send the UUID of the document entry object that is associated with the
old document. You should be able to do this with a simple XDS query
prior to submitting the replacement.
hope this helps,
- Sarah
> Dmitry
Re: Requesting correction of the original document [message #49206 is a reply to message #49128] Tue, 14 October 2008 15:40 Go to previous messageGo to next message
Hi Sarah,
Thanks for your response.
I think that replacement option on the XDS Source which you are describing
and "correction request" are two different functions.
Is it that such correction request does not exist in IHE framework?
Dmitry
Re: Requesting correction of the original document [message #49288 is a reply to message #49206] Thu, 16 October 2008 14:01 Go to previous message
Hi Dmitry,
At this point in time, "correction" is handled by document replacement.
Life cycle issues are becomming more and more of an issue in IHE. They
have the following whitepaper that I encourage everyone to read:
ftp://ftp.ihe.net/IT_Infrastructure/iheitiyr6-2008-2009/Tech nical_Cmte/Whitepaper_Work/Metadata_Versioning/metadata_vers ioning_08.doc
(posted on an earlier thread)
regards,
Sarah
> Hi Sarah,
> describing and "correction request" are two different functions.
> Dmitry
Re: Requesting correction of the original document [message #587935 is a reply to message #49068] Fri, 10 October 2008 17:23 Go to previous message
Hi Dmitry,
hope this helps,
- Sarah
> Dmitry
Re: Requesting correction of the original document [message #587965 is a reply to message #49128] Tue, 14 October 2008 15:40 Go to previous message
Hi Sarah,
Dmitry
Re: Requesting correction of the original document [message #587980 is a reply to message #49206] Thu, 16 October 2008 14:01 Go to previous message
Hi Dmitry,
regards,
Sarah
> Hi Sarah,
> Dmitry
Previous Topic:Will SAT be maintained
Next Topic:OHF Project to be closed?!
Current Time: Fri Jul 18 05:51:59 EDT 2025
Powered by FUDForum. Page generated in 0.19318 seconds
