Configuro Output [message #4293] |
Tue, 16 June 2009 22:50  |
Is there a way to reduce the amount of data currently being spewed out by
the tools/configuro? Do we really need all the info (Generating
interfaces, etc.)? For top-level build I would just want to see something
like âRunning configuration step for app.cfgâ, not all the data. What
I believe is just the ânormalâ info being output seems more
appropriate to a âverboseâ output. All the stuff spewing out makes
some people nervous because they feel disconnected from whatâs
happening, i.e. too much stuff whizzing past on the screen. I think
something like âRunning configuration step for app.cfgâ would be
easier to follow. Only if something is screwed up would I want to see
more.
Re: Configuro Output [message #4640 is a reply to message #4571] |
Wed, 24 June 2009 11:21  |
dave russo wrote:
> Brad Griffis wrote:
>> Yes, I think a --quiet would be good. In the case of some kind of
>> error/warning then it would be good for it to tell us that it's an error
>> compiling a file or whatever it might be. In other words, don't tell me
>> what you're doing unless something goes wrong. In most cases I would
>> expect/hope to get enough info from the error message to fix the problem
>> without having to turn off --quiet and re-do the build.
>> So potentially this may require a little re-working of some error
>> messages. If the error message is overly dependent on the user having
>> all the status info then we may want to repeat that info in the error
>> message.
> The problem is that the configuration process involves many tools that
> XDC does not control; as a result, many of the error messages _can't_ be
> changed. For example, errors can come from the target's
> compiler/linker, GNU make, cygwin, ...
Let's try it out and we'll see how it goes. If nothing else, once we get
things building properly it will be nice to throw the --quiet switch and
simplify/shrink the build output.
FUDForum. Page generated in 0.06516 seconds
