Home » Archived » DSDP - Real-Time Software Components (RTSC) » Configuro Output
Configuro Output [message #4293] Tue, 16 June 2009 22:50 Go to next message
Is there a way to reduce the amount of data currently being spewed out by
the tools/configuro? Do we really need all the info (Generating
interfaces, etc.)? For top-level build I would just want to see something
like “Running configuration step for app.cfg”, not all the data. What
I believe is just the “normal” info being output seems more
appropriate to a “verbose” output. All the stuff spewing out makes
some people nervous because they feel disconnected from what’s
happening, i.e. too much stuff whizzing past on the screen. I think
something like “Running configuration step for app.cfg” would be
easier to follow. Only if something is screwed up would I want to see
more.
Re: Configuro Output [message #4432 is a reply to message #4293] Wed, 17 June 2009 10:48 Go to previous messageGo to next message
> by the tools/configuro? Do we really need all the info (Generating
> something like "Running configuration step for app.cfg", not all the
> data. What I believe is just the "normal" info being output seems
> more appropriate to a "verbose" output. All the stuff spewing out
> makes some people nervous because they feel disconnected from what's
> something like "Running configuration step for app.cfg" would be
> more.
I agree.
On the other hand, there are good reasons for keeping the output. The
output provides feedback about the tools progress (which can take some
time) and when something goes wrong the error message makes more sense
in the context of what the tool is doing at the time. For example,
errors may come from the target's compiler and, without a message saying
we are compiling a specific file, it _really_ does not make sense.
Perhaps a --quite flag can be added to xdc.tools.configuro to eliminate
the progress messages.
Re: Configuro Output [message #4501 is a reply to message #4432] Wed, 17 June 2009 12:08 Go to previous messageGo to next message
Yes, I think a --quiet would be good. In the case of some kind of
error/warning then it would be good for it to tell us that it's an error
compiling a file or whatever it might be. In other words, don't tell me
what you're doing unless something goes wrong. In most cases I would
expect/hope to get enough info from the error message to fix the problem
without having to turn off --quiet and re-do the build.
So potentially this may require a little re-working of some error
messages. If the error message is overly dependent on the user having all
the status info then we may want to repeat that info in the error message.
Re: Configuro Output [message #4571 is a reply to message #4501] Wed, 17 June 2009 12:42 Go to previous messageGo to next message
> all the status info then we may want to repeat that info in the error
> message.
The problem is that the configuration process involves many tools that
XDC does not control; as a result, many of the error messages _can't_ be
changed. For example, errors can come from the target's
compiler/linker, GNU make, cygwin, ...
Re: Configuro Output [message #4640 is a reply to message #4571] Wed, 24 June 2009 11:21 Go to previous message
>> message.
Let's try it out and we'll see how it goes. If nothing else, once we get
things building properly it will be nice to throw the --quiet switch and
simplify/shrink the build output.
Previous Topic:compilation error in "RTSC Module Primer" Lesson2
Next Topic:XDC Producer's Guide
Current Time: Wed Nov 19 06:50:43 EST 2025
Powered by FUDForum. Page generated in 0.20331 seconds
