Home » Newcomers » Newcomers » main.java
main.java [message #48978] Thu, 07 April 2005 20:08 Go to next message
I created a project with a package and a main inside it.
I ended up moving main.java outside the package then back inside.
The project does not run anymore.
It cannot define aType as there is no list of type in teh type box.
any idea how to get out of this?
thanks
Laurie
Re: main.java [message #49071 is a reply to message #48978] Fri, 08 April 2005 04:21 Go to previous message
Originally posted by: user.server.net
Laurie,
This might sound to easy and most probabely you checked it already: What
class do the settings in your run preferences point to? You might need
to adapt them when moving the class into a package different from the
default package. Just lounching the project with "Run" might fail.
Kai
> thanks
> Laurie
Previous Topic:Where are Projects Stored
Next Topic:Using Eclipse's CVS client with an already checked out project
Current Time: Wed Jul 16 18:52:19 EDT 2025
Powered by FUDForum. Page generated in 0.09539 seconds
