Home » Archived » XML Schema Definition (XSD) » Remove XSD manually to Rinstall
Remove XSD manually to Rinstall [message #48921] |
Tue, 13 July 2004 10:25  |
Originally posted by: hervais.club-internet.fr
Using Eclipse 3.0.0
I had some problems with emf and XSD 2.0 installation
I could remove EMF manually to reinstall it ,
but I couldn't do the same with XSD (and the 2 other xml files).
XSD is complaning for this :
No plug-in: "org.eclipse.xsd" included at runtime.
No plug-in: "org.eclipse.xsd.edit" included at runtime.
No plug-in: "org.eclipse.xsd.editor" included at runtime.
No plug-in: "org.eclipse.xsd.test" included at runtime.
No plug-in: "org.eclipse.emf.mapping.xsd2ecore" included at runtime.
No plug-in: "org.eclipse.emf.mapping.xsd2ecore.editor" included at runtime.
Can you give me a hint?
Best regards, MH
Re: Remove XSD manually to Rinstall [message #49119 is a reply to message #49091] |
Mon, 19 July 2004 16:38   |
Well, I tried the clean flag without knowing exactly what it does but the
problem stays.
A complete install is exactly chat I would like to avoid
whet would ve the effects of removing the eclipse/configuration directory ?
thanks
user@domain.invalid wrote:
> have you started eclipse with the -clean flag? eclipse -clean
> norwood sisson
> Ed Merks wrote:
> > Maybe removing the eclipse/configuration directory will help. Or doing
> > a scratch install of everything...
> > mherv wrote:
> >>No, it looks like the plugins reside wher they should.
> >>For your info, I installed v201 and v200 gets disables, but the same error
> >>remains
> >>Thanks for help
> >>Sincerely, MH
> >>Ed Merks wrote:
> >>>I'm not sure what manual steps you've taken, but it sounds like maybe
> >>>the XSD plugins are simply missing.
> >>>mherv wrote:
> >>>>Hi,
> >>>>Using Eclipse 3.0.0
runtime.
> >>>>Best regards, MH
Re: Remove XSD manually to Rinstall [message #49148 is a reply to message #49119] |
Tue, 20 July 2004 09:01  |
--------------060109020406060808060307
Content-Type: text/plain; charset=us-ascii; format=flowed
I'm not sure what the clean flag does, but removing the configuration
directory should just clean up cached plugin installation information
that may not be up to date.
>problem stays.
>thanks
>>norwood sisson
>>>>remains
>>>>Thanks for help
>>>>Sincerely, MH
>>>>>mherv wrote:
>>>>>>Hi,
>>>>>>Using Eclipse 3.0.0
>runtime.
>>>>>>Best regards, MH
Content-Type: text/html; charset=us-ascii
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
that may not be up to date.<br>
<br>
<br>
mherv wrote:
<blockquote cite="midcdhbfg$844$1@eclipse.org" type="cite">
<pre wrap="">Well, I tried the clean flag without knowing exactly what it does but the
problem stays.
thanks
<a class="moz-txt-link-abbreviated" href="mailto:user@domain.invalid">user@domain.invalid</a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">have you started eclipse with the -clean flag? eclipse -clean
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">norwood sisson
</pre>
</blockquote>
</pre>
<pre wrap="">Ed Merks wrote:
</pre>
<pre wrap="">Maybe removing the eclipse/configuration directory will help. Or doing
mherv wrote:
</pre>
<pre wrap="">No, it looks like the plugins reside wher they should.
remains
Thanks for help
Sincerely, MH
Ed Merks wrote:
</pre>
<pre wrap="">I'm not sure what manual steps you've taken, but it sounds like maybe
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap="">mherv wrote:
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap="">Hi,
Using Eclipse 3.0.0
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->runtime.
</pre>
<pre wrap="">Can you give me a hint?
Best regards, MH
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060109020406060808060307--
Re: Remove XSD manually to Rinstall [message #589709 is a reply to message #48921] |
Tue, 13 July 2004 10:44  |
mherv wrote:
>Hi,
>Using Eclipse 3.0.0
>Best regards, MH
Re: Remove XSD manually to Rinstall [message #589750 is a reply to message #48955] |
Sat, 17 July 2004 07:57  |
remains
Thanks for help
Sincerely, MH
> mherv wrote:
> >Hi,
> >Using Eclipse 3.0.0
> >Best regards, MH
Re: Remove XSD manually to Rinstall [message #589763 is a reply to message #49038] |
Mon, 19 July 2004 07:15  |
--------------000208070106000602010605
>remains
>Thanks for help
>Sincerely, MH
>>mherv wrote:
>>>Hi,
>>>Using Eclipse 3.0.0
>>>Best regards, MH
<html>
<head>
<title></title>
</head>
Re: Remove XSD manually to Rinstall [message #589777 is a reply to message #49066] |
Mon, 19 July 2004 11:28  |
norwood sisson
>>remains
>>Thanks for help
>>Sincerely, MH
>>>mherv wrote:
>>>>Hi,
>>>>Using Eclipse 3.0.0
>>>>Best regards, MH
Re: Remove XSD manually to Rinstall [message #589784 is a reply to message #49091] |
problem stays.
thanks
> norwood sisson
> >>remains
> >>Thanks for help
> >>Sincerely, MH
> >>>mherv wrote:
> >>>>Hi,
> >>>>Using Eclipse 3.0.0
runtime.
> >>>>Best regards, MH
Re: Remove XSD manually to Rinstall [message #589796 is a reply to message #49119] |
>problem stays.
>thanks
>>norwood sisson
>>>>remains
>>>>Thanks for help
>>>>Sincerely, MH
>>>>>mherv wrote:
>>>>>>Hi,
>>>>>>Using Eclipse 3.0.0
>runtime.
>>>>>>Best regards, MH
<html>
<head>
<title></title>
</head>
<br>
<br>
problem stays.
thanks
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
mherv wrote:
</pre>
remains
Thanks for help
Sincerely, MH
Ed Merks wrote:
</pre>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap="">Hi,
Using Eclipse 3.0.0
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
Best regards, MH
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Tue Jul 15 13:50:14 EDT 2025
Powered by FUDForum. Page generated in 0.28827 seconds
