Using standalone OSGI bundles in Eclipse [message #48788] |
Thu, 14 July 2005 09:00  |
Originally posted by: USERjimirwin.DOMAINacm.org
My application is being written to run in the Eclipse workbench, but we
have future plans to split off parts that will run on remote servers. One
of the things we need to do is allow third parties to write addins to our
application.
I would like to allow third parties to write OSGi bundles to implement a
service interface that we specify, for instance to allow third parties to
write import services that transform their proprietary data formats into
our data model specification. I don't want to ask the third parties to re-
implement their addins for another non-Eclipse environment, so I would like
to be able to use addins that are not Eclipse dependent.
In phase 1 of our application which runs within Eclipse as a plugin, I
would like to have Eclipse install the third party OSGi bundles and make
them available to our application.
It appears that the problem is to get Eclipse to start the bundles and
allow them to register their services. Ideally, I would like to have that
under the control of my application, for instance to wait until the user
selects a particular import type before starting the bundle -- in other
words, lazy startup under the control of my application.
Finally, I would like to deploy the third-party addins within my plugin's
directory, for instance in eclipse/plugins/com.me.myapp_1.0.0/addins. It
appears that Eclipse 3.1 automatically discovers those bundles and installs
them, but doesn't start them. That means they don't get a chance to
register their services, and I can't discover their presence.
One workaround that might work is to get all bundles from my BundleContext,
and then walk through the list to find out if they came from my addin
directory, and then examine some property from the manifest to see if they
advertise support for my application, and then start them if I need to use
them.
This seems a little unwieldy. Is there a better way to accomplish it that
I overlooked or failed to find?
Thanks.
Jim Irwin
http://www.holoscenes.com
Re: Using standalone OSGI bundles in Eclipse [message #49079 is a reply to message #48788] |
Mon, 08 August 2005 11:44   |
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Jim,
Sorry for the delay in answering this. Much of the team has been on holiday
etc. See embedded comments...
"jimirwin" <USERjimirwin@DOMAINacm.org> wrote in message
news:Xns96935B9ADD530jrixnews@206.191.52.34...
This is in fact the standard "Eclipse way". run no code before its time.
If you look at standard Eclipse bundles they all have Eclipse-Autostart:
true in the MANIFEST.MF. This is a signal to the runtime that this bundle
should be automatically started if someone attempts to load a class that it
supplies. The entire Eclipse UI (which is just an OSGi based application)
works this way. Click on a menu entry and the act of running the Action
causes the action to get loaded and the supplying plugin to be activated.
installs
Ok, this is a bit different then what you are talking about above. If you
want the services registered, you have to start the bundles. That is the
way OSGi works. Declarative services are coming in R4 but not yet...
BundleContext,
> them.
It is a little unwieldy but not all that unnatural. In effect that is what
the Eclipse Extension Registry and the OSGi Declarative services mechanisms
do. Check out EclipseBundleListener. It listens for bundles to become
resovled and then looks at them to see if they have a plugin.xml file. If
they do it parses the file and adds contents to the extension registry.
Jeff
Re: Using standalone OSGI bundles in Eclipse [message #54659 is a reply to message #54032] |
Mon, 12 December 2005 18:00  |
Ah, sure there are several parsers etc. Check out the parser code in the
new org.eclipse.equinox.registry bundle.
Jeff
"Kai Klesatschke" <kai.klesatschke@netallied.de> wrote in message
news:dmp0k1$hdp$1@news.eclipse.org...
> Jeff McAffer wrote:
> > Gadzooks Kai!
> Ups, did I ask about a no-no?
> > why would you want to manually parse these things?
> The idea:
> I thought about using a runtime configuration for some sort of a "core"
> plugin. The config (xml) sets the preferences for each bundle it needs
> to run properly. The definition of the config elements for a specific
> bundle should be defined by a schema (exsd like) provided by the
> corresponding bundle.
> Why the question:
> The extension point schema is similar to my approach and I wanted to
> have a look at equinox if there is some reuseable code.
FUDForum. Page generated in 0.34012 seconds
