Home » Eclipse Projects » GEF » Again Layers
Again Layers [message #48636] Tue, 10 December 2002 04:49 Go to next message
like in another posting I want the connections _not_ to be layered on
top of my nodes, but want them behind them.
In FreeformGraphicalRootEditPart#createFigure() the layers are added,
changing the order if adding (e.g. adding the connection layer first in
a subclass) makes the connections disappear completely.
How to achieve that?
Thank you,
Chris
Re: Again Layers [message #48697 is a reply to message #48636] Tue, 10 December 2002 12:00 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
The primary layer is set to be opaque. It is filling white on top of your
connections. You need to make it transparent.
"Chris" <wibni@web.de> wrote in message news:3DF5B8A9.1090900@web.de...
> Hello,
> Thank you,
> Chris
Re: Again Layers [message #48814 is a reply to message #48697] Wed, 11 December 2002 07:02 Go to previous messageGo to next message
I still do not understand how to do it.
I subclasses FreeformGraphicalRootEditPart where I implemented createFigure:
FreeformViewport viewport = new FreeformViewport();
myInnerLayers = new FreeformLayeredPane();
myInnerLayers.add(new ConnectionLayer(), CONNECTION_LAYER);
FreeformLayer tmpLayer = new FreeformLayer();
// I thought this would stop overpaiting my connections:
tmpLayer.setOpaque(false);
myInnerLayers.add(tmpLayer, PRIMARY_LAYER);
myInnerLayers.add(new FreeformLayer(), HANDLE_LAYER);
myInnerLayers.add(new MyFeedbackLayer(), FEEDBACK_LAYER);
viewport.setContents(myInnerLayers);
return viewport;
Any hints?
Chris
Re: Again Layers [message #48844 is a reply to message #48814] Wed, 11 December 2002 09:26 Go to previous messageGo to next message
Your contents EditPart is most likely opaque too.
"Chris" <wibni@web.de> wrote in message news:3DF72955.4000901@web.de...
your
createFigure:
> return viewport;
> Any hints?
> Chris
Re: Again Layers [message #48931 is a reply to message #48844] Wed, 11 December 2002 11:58 Go to previous messageGo to next message
Thanks, now the connections are in the background, behind the nodes!
But unfortunately no Drag&Drop of my nodes is possible anymore...
Anyone an idea?
Chris
> your
> createFigure:
>>return viewport;
>>Any hints?
>>Thanks,
>>Chris
Re: Again Layers [message #48960 is a reply to message #48931] Wed, 11 December 2002 18:51 Go to previous messageGo to next message
Your primary layer isn't being targeted because it is transparent.
you will have to change containsPoint(int, int) in the figure that
represents your contents EditPart.
Note that in TransparentFigure, the Layer will *never* be targeted (it will
never return this) unless it is opaque.
"Chris" <wibni@web.de> wrote in message news:3DF76EA9.7030209@web.de...
> Anyone an idea?
> Chris
> > your
> > createFigure:
> >>return viewport;
> >>Any hints?
> >>Thanks,
> >>Chris
Re: Again Layers [message #50398 is a reply to message #48960] Wed, 18 December 2002 10:44 Go to previous message
Ok, now I subclassed FreeformLayer for my contents edit part figure and
overwrote the methods findFigureAtExcluding and containsPoint, and
everything works fine.
Actually I implemented them _exactly_ like they are allready implemented
in Figure, I re-invented behaviour allready implemented in the
super-super-super-super class. Though working this seems not very
elegant.. Ist there a better way doing this?
I think having a layer that is non-opaque _and_ targetable can be a
widely used component and should be part of the Figure hierarchy.
Thanks for help!
Chris
>>Anyone an idea?
>>Chris
>>>your
>>>createFigure:
>>>>return viewport;
>>>>Any hints?
>>>>Thanks,
>>>>Chris
Previous Topic:layout fot root figure
Next Topic:Dumb questions on TreeView
Current Time: Wed Dec 03 03:23:24 EST 2025
Powered by FUDForum. Page generated in 0.31795 seconds
