Home » Language IDEs » PHP Development Tools (PDT) » Can't get PHP Web Script with XDebug to hit breakpoints remotely
Can't get PHP Web Script with XDebug to hit breakpoints remotely [message #48621] Fri, 31 August 2007 18:15 Go to next message
I'm using XDebug 2 on a Linux server running Apache 2. I can communicate
successfully with the debugclient app from my Windows XP machine.
I then try to run Eclipse 3.3 on my Windows machine w/ all the necessary
packages (pdt-all-in-one-incubation-S20070826_M3-win32.zip), plus the two
jar files from XDebugBinContrib_0.2.3.zip and
org.eclipse.php.xdebug.sampleMapper_0.0.2.jar.
I've configured my Eclipse debug configuration per Dave Kelsey's "XDebug PHP
IDE Guide" (including the HTDoc tab), and set some breakpoints. When I
launch, an IE browser window opens and displays all the expected output,
ignoring the breakpoints. The PHP Debug view shows that the project is
terminated. I've tried different settings on the HTDoc tab, but without
success.
The log output from the server side is as follows:
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
Log opened at 2007-08-31 22:01:30
-> <init xmlns="urn:debugger_protocol_v1"
xmlns:xdebug="http://xdebug.org/dbgp/xdebug"
fileuri="file:///var/local/raas/document_root_apache2/test.php"
language="PHP" protocol_version="1.0" appid="31453"
idekey="ECLIPSE_DBGP"><engine
version="2.0.0"><![CDATA[Xdebug]]></engine><author><![CDATA[Derick
Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright
(c) 2002-2007 by Derick Rethans]]></copyright></init>
-> <response xmlns="urn:debugger_protocol_v1"
xmlns:xdebug="http://xdebug.org/dbgp/xdebug" status="stopped"
reason="ok"></response>
Log closed at 2007-08-31 22:01:30
This is exactly the same output as I got when I tested debugclient from my
Windows machine.
Is this what I should be seeing if I had no breakpoints? Any idea why I'm
not hitting any breakpoints? Can I turn on any additional logging on the
eclipse client side? Or can I make the server logging more verbose?
Dennis
Re: Can't get PHP Web Script with XDebug to hit breakpoints remotely [message #48650 is a reply to message #48621] Fri, 31 August 2007 22:19 Go to previous messageGo to next message
This "issue" has already been addressed in the past week. Please read the
thread "Can't get XDebug to work" originally created by myself. Remote
debugging is currently not possible however Dave Kelsey hopes to have a
solution for this soon.
Marijn.
Re: Can't get PHP Web Script with XDebug to hit breakpoints remotely [message #48709 is a reply to message #48621] Sat, 01 September 2007 04:03 Go to previous messageGo to next message
XDebug support is included in M3, so you should not install the XDebug
zip files from bugzilla any more.
As pointed out by Marijn, unfortunately there is no solution for path
mapping as yet in M3.
Dave Kelsey
> success.
> Windows machine.
> Dennis
Re: Can't get PHP Web Script with XDebug to hit breakpoints remotely [message #48886 is a reply to message #48709] Mon, 03 September 2007 12:27 Go to previous message
Hi Dave,
Thanks for the reply. I've now backtracked to M2 + the bugzilla xdebug and
mapper jar files, and it seems to be working fine, breakpoints and all.
I'll look forward to M4 (or whatever it will be called), which hopefully
will have xdebug support restored.
Thanks again for all the good work.
Dennis
"Dave Kelsey" <dkel50@hotmail.com> wrote in message
news:fbb6d3$7os$1@build.eclipse.org...
> Dave Kelsey
>> PHP IDE Guide" (including the HTDoc tab), and set some breakpoints. When
>> I launch, an IE browser window opens and displays all the expected
>> output, ignoring the breakpoints. The PHP Debug view shows that the
>> project is terminated. I've tried different settings on the HTDoc tab,
>> but without success.
>> my Windows machine.
>> Thanks,
>> Dennis
Previous Topic:Specifying command line arguments for php scripts
Next Topic:Problem Occurred Processing Dirty Regions
Current Time: Mon Jun 02 01:49:41 EDT 2025
Powered by FUDForum. Page generated in 0.03409 seconds
