Home » Archived » EPF » EPF Composer Development Question
EPF Composer Development Question [message #48560] Wed, 05 March 2008 12:21 Go to next message
Originally posted by: danielcounts.gmail.com
Any guidance will be appreciated
1. Downloaded and installed all components into a clean directory per the
EPF Composer Development Guide
2. Found several sets of .ecore and .genmodel files so used the .genmodel
found in org.eclipse.epf.uma\model\1.0.4.
3. Selected the Generate Model Code menu option.
4. After re-building the project, received the following 3 errors:
a. The method getParentPackage() is undefined for the type MethodPackage
org.eclipse.epf.authoring.ui/src/org/eclipse/epf/authoring/u i/forms ConfigurationPage.java line
1134 1204734694656 233673
b. The method getParentPackage() is undefined for the type
MethodPackage org.eclipse.epf.search.ui/src/org/eclipse/epf/search/ui/inte rnal SearchResultTreeContentProvider.java line
181 1204734700296 234743
c. The method getParentPackage() is undefined for the type
ProcessPackage org.eclipse.epf.search.ui/src/org/eclipse/epf/search/ui/inte rnal SearchResultTreeContentProvider.java line
213 1204734700296 234744
TIA,
Dan
Re: EPF Composer Development Question [message #48590 is a reply to message #48560] Wed, 05 March 2008 16:18 Go to previous message
My bad.
Evidently I didn't do what I thought I did.
re-started from scratch and no errors were received.
Dan
"Dan Counts" <danielcounts@gmail.com> wrote in message
news:19051795d3ed49127889abbac72a9342$1@www.eclipse.org...
> ConfigurationPage.java line 1134 1204734694656 233673
> b. The method getParentPackage() is undefined for the type MethodPackage
> SearchResultTreeContentProvider.java line 181 1204734700296 234743
> c. The method getParentPackage() is undefined for the type ProcessPackage
> SearchResultTreeContentProvider.java line 213 1204734700296 234744
> TIA,
> Dan
Re: EPF Composer Development Question [message #588601 is a reply to message #48560] Wed, 05 March 2008 16:18 Go to previous message
My bad.
Dan
> TIA,
> Dan
Previous Topic:EPF Composer Development Question
Next Topic:Creating new fields
Current Time: Thu Nov 06 16:05:18 EST 2025
Powered by FUDForum. Page generated in 0.03283 seconds
