Home » Archived » Visual Editor (VE) » How can I define an Attachment for a FormLayout?
How can I define an Attachment for a FormLayout? [message #48550] Tue, 06 July 2004 22:52
I´m trying to use VE to create a Shell that uses FormLayout.
I defined the Shell to have FormLayout, and added a Label. Then, on
LayoutData I tried to define the Attachments (top, left, bottom and
right), but the property is empty and "read-only".
Is FormLayout already enabled on VE?
I tried with "Customize Layout" context popup, but neither for the
Shell, neither for the Label appeared any kind of customization. It
stays with the message "No layout options to customize on the current
selection" for anything.
Thanks in advance
Alessandro
Previous Topic:Integration Build available for VE milestone 2 integration test
Next Topic:How can I define an Attachment for a FormLayout?
Current Time: Fri Nov 07 16:46:37 EST 2025
Powered by FUDForum. Page generated in 0.03138 seconds
