| MTL Project - first evaluation [message #48440] |
Fri, 08 August 2008 18:14  |
Hi MTL-Team,
i've installed the today release of your MTL implemenation. I have
problems, to get it run. My current approach is the following:
final URI tmp = URI.createFileURI("...");
final URI model = URI.createFileURI("...");
File output = new File("..");
final List<URI> tmpls = new Vector<URI>();
tmpls.add(tmp);
final List<File> files = new Vector<File>();
files.add(new File("..."));
MTLParser parser = new MTLParser(); //parse the mtl-file
parser.parse(files, tmpls, new Vector());
ResourceSet set = new ResourceSetImpl(); //causes an Exception
Resource s = set.getResource(tmp, true);
Module moduled = (Module)s.getContents().get(0);
System.out.println(moduled.getName());
ResourceSet rss = new ResourceSetImpl();
Resource rs = rss.getResource(model, true);
EObject umlModel = rs.getContents().get(0).eContents().get(4);
MTLService.doGenerate(moduled, "generate", umlModel, output);
The module will be correctly transformed into an UML model, but it
cannot be parsed. As i mentioned as a comment in the snippet, an
Exception is thrown:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'XMI' not found.
(file:/F:/Softwareentwicklung/Eclipse/runtime-EclipseApplica tion/Test/templates/generateModel.mtl,
2, 236)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at runner.TransformationRunner.testTranse(TransformationRunner. java:34)...
Can you verify, whether my approach is the correct one?
And some more general questions:
1. The MTL module project is ment for the creation of user defined modules?
2. The module UI project for the creation of specific UI things.
Thank you for your answers, and i hope i can give you some more feedback
about bugs in the project in the future.
Cheers
Timothy
| Re: MTL Project - first evaluation [message #48466 is a reply to message #48440] |
Mon, 11 August 2008 03:56  |
Hi Timoty,
It is dificult to initialize the parser your-self...
At the moment you should use the wizards and the eclipse builder to
initialize your generator
"New>MTL>MTL Module Project"
You have to create one MTL file
The MTL builder creates atomatically a java class next to the MTL file
(only if the MTL file contains a [file] block)
This java class is the entry point of your module, if you want to call
it programmatically.
An ANT task is also created by the builder in the folder 'tasks' of the
project.
The last build is I200808081155.
Jonathan
Timothy Marc a écrit :
> Hi MTL-Team,
> tmpls.add(tmp);
> 2, 236)
> at
> at
> at
> at
> Cheers
> Timothy
H
FUDForum. Page generated in 0.11847 seconds
