Home » Language IDEs » AspectJ » Can I use AspectJ 1.2.1?
Can I use AspectJ 1.2.1? [message #48394] Mon, 21 February 2005 06:06 Go to next message
Hi all,
Can I use AspectJ 1.2.1 instead of the buil-in aspectj_1.1.12 with
ajdt_1.1.12?
Re: Can I use AspectJ 1.2.1? [message #48423 is a reply to message #48394] Mon, 21 February 2005 12:38 Go to previous messageGo to next message
Andy Clement answered this on the aspectj-users e-mail list. If I can
quote him:
Inside org.aspectj.ajde is ajde.jar - this is a repackaged version of the
aspectjtools.jar that comes with an AspectJ standalone download.
The bit of ANT to construct a new ajde.jar from an aspectjtools.jar is
simply:
<unzip dest="${ajde.build.dir}" src="aspectjtools.jar" />
<delete includeemptydirs="true">
<fileset dir="${ajde.build.dir}">
<exclude name="org/aspectj/**/*.*" />
</fileset>
</delete>
<zip destfile="ajde.jar">
<fileset dir="${ajde.build.dir}" />
</zip>
However ... be very careful when reporting bugs if you have modified
your setups ... we need to know what you have been doing.
-adrian.
David Perez wrote:
> Hi all,
> ajdt_1.1.12?
Re: Can I use AspectJ 1.2.1? [message #48457 is a reply to message #48394] Tue, 22 February 2005 05:45 Go to previous messageGo to next message
Hi David,
AJDT 1.1.12 already contains AspectJ 1.2.1. If you click 'Help' >
'About Eclipse Platform' > 'Plug-in Details' you should see AspectJ
listed with 1.2.1 as the version number. We wouldn't recommend
upgrading your AspectJ version in AJDT 1.1.12 because several of the
interfaces between AJDT and AJDE have changed recently.
Sian
David Perez wrote:
> Hi all,
> ajdt_1.1.12?
Re: Can I use AspectJ 1.2.1? [message #48487 is a reply to message #48457] Tue, 22 February 2005 10:12 Go to previous message
Sian January wrote:
> Hi David,
> Sian
> David Perez wrote:
>> Hi all,
>> ajdt_1.1.12?
Thanks, it wasn't clear for me the used version of AspectJ, which is very
important for knowing what you can do or can't.
Re: Can I use AspectJ 1.2.1? [message #586854 is a reply to message #48394] Mon, 21 February 2005 12:38 Go to previous message
quote him:
simply:
</fileset>
</delete>
</zip>
-adrian.
David Perez wrote:
> Hi all,
> ajdt_1.1.12?
Re: Can I use AspectJ 1.2.1? [message #586858 is a reply to message #48394] Tue, 22 February 2005 05:45 Go to previous message
Hi David,
Sian
David Perez wrote:
> Hi all,
> ajdt_1.1.12?
Re: Can I use AspectJ 1.2.1? [message #586875 is a reply to message #48457] Tue, 22 February 2005 10:12 Go to previous message
Sian January wrote:
> Hi David,
> Sian
> David Perez wrote:
>> Hi all,
>> ajdt_1.1.12?
Previous Topic:Can I use AspectJ 1.2.1?
Next Topic:Where are inpath settings stored?
Current Time: Mon Jul 14 22:33:53 EDT 2025
Powered by FUDForum. Page generated in 0.47095 seconds
