| Re: Can I use AspectJ 1.2.1? [message #48487 is a reply to message #48457] |
Tue, 22 February 2005 10:12  |
Sian January wrote:
> Hi David,
> AJDT 1.1.12 already contains AspectJ 1.2.1. If you click 'Help' >
> 'About Eclipse Platform' > 'Plug-in Details' you should see AspectJ
> listed with 1.2.1 as the version number. We wouldn't recommend
> upgrading your AspectJ version in AJDT 1.1.12 because several of the
> interfaces between AJDT and AJDE have changed recently.
> Sian
> David Perez wrote:
>> Hi all,
>> Can I use AspectJ 1.2.1 instead of the buil-in aspectj_1.1.12 with
>> ajdt_1.1.12?
Thanks, it wasn't clear for me the used version of AspectJ, which is very
important for knowing what you can do or can't.
| Re: Can I use AspectJ 1.2.1? [message #586854 is a reply to message #48394] |
Mon, 21 February 2005 12:38  |
Andy Clement answered this on the aspectj-users e-mail list. If I can
quote him:
Inside org.aspectj.ajde is ajde.jar - this is a repackaged version of the
aspectjtools.jar that comes with an AspectJ standalone download.
The bit of ANT to construct a new ajde.jar from an aspectjtools.jar is
simply:
<unzip dest="${ajde.build.dir}" src="aspectjtools.jar" />
<delete includeemptydirs="true">
<fileset dir="${ajde.build.dir}">
<exclude name="org/aspectj/**/*.*" />
</fileset>
</delete>
<zip destfile="ajde.jar">
<fileset dir="${ajde.build.dir}" />
</zip>
However ... be very careful when reporting bugs if you have modified
your setups ... we need to know what you have been doing.
-adrian.
David Perez wrote:
> Hi all,
> ajdt_1.1.12?
| Re: Can I use AspectJ 1.2.1? [message #586858 is a reply to message #48394] |
Tue, 22 February 2005 05:45  |
Hi David,
Sian
David Perez wrote:
> Hi all,
> ajdt_1.1.12?
| Re: Can I use AspectJ 1.2.1? [message #586875 is a reply to message #48457] |
Sian January wrote:
> Hi David,
> Sian
> David Perez wrote:
>> Hi all,
>> ajdt_1.1.12?
FUDForum. Page generated in 0.04872 seconds
