| org.eclipse.rwt.clientLogLevel - how to use? [message #48354] |
Wed, 19 September 2007 13:59  |
Hi, I am not getting the VM argument "org.eclipse.rwt.clientLogLevel" to do
anything. I have added -Dorg.eclipse.rap.rwt.clientLogLevel=ALL to my
launch configuration, but I don't see any additional logging to the console,
nor do I see the extra window described in this bug comment:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=189686, Comment 4.
"Note:
If you specify -Dorg.eclipse.swt.clientLogLevel=ALL as a VM argument in your
launch configuration there will be opened a secondary browser window that
shows debug and error messages."
I have tried both the old (with
"swt", -Dorg.eclipse.rap.swt.clientLogLevel=ALL) and new (with
"rwt", -Dorg.eclipse.rap.rwt.clientLogLevel=ALL) arguments (the change of
the argument is mentioned here:
http://wiki.eclipse.org/index.php/Rap10M6_News).
Is there any documentation on org.eclipse.rwt.clientLogLevel and the other
VM arguments? Or at least a list of them?
Ryan Donnelly
| Re: org.eclipse.rwt.clientLogLevel - how to use? [message #48384 is a reply to message #48354] |
Wed, 19 September 2007 16:10  |
Originally posted by: rsternberg.innoopract.com
Hi Ryan,
> do anything. I have added -Dorg.eclipse.rap.rwt.clientLogLevel=ALL to
leave out the ".rap" and you'll probably get the the extra window. The
correct parameter is "org.eclipse.rwt.clientLogLevel". If you have
Firebug installed, it could also be that the logging goes directly to
the Firebug console.
> my launch configuration, but I don't see any additional logging to the
> console, nor do I see the extra window described in this bug comment:
> "Note:
> your launch configuration there will be opened a secondary browser
> window that shows debug and error messages."
> I have tried both the old (with "swt",
> -Dorg.eclipse.rap.swt.clientLogLevel=ALL) and new (with "rwt",
> -Dorg.eclipse.rap.rwt.clientLogLevel=ALL) arguments (the change of the
> other VM arguments? Or at least a list of them?
No, a proper documentation on these parameters is still missing, but
we're currently adding some more articles to the RAP Help. Of course,
the properties should also be covered there.
Anyway, the important properties are:
- org.osgi.service.http.port
- org.eclipse.rwt.clientLogLevel=ALL to enable client logging
- org.eclipse.rwt.clientLibraryVariant=DEBUG for using a
debugging-enabled qx lib instead of the performance-optimized one
Hope that helps so far,
Ralf
FUDForum. Page generated in 0.02865 seconds
