| master page margins [message #48298] |
Mon, 20 June 2005 15:17  |
I'm trying to find my way in BIRT (on Ubuntu Linux).
One of the problems I keep running into is that I can't set the master
page margins.
Whatever values I enter for whatever measurement unit (cm, inch, ...), I
keep getting a 'for input string ' error.
The logs tell me that this has to do with a
'java.lang.NumberFormatException', but that doesn't help me to solve this
problem.
Any help is appreciated...
Bart
| Re: master page margins [message #50774 is a reply to message #50003] |
Thu, 23 June 2005 15:15  |
Hi Rima,
I've sent the report design file to you by e-mail.
I did set the margins of the master page throught the property editor UI.
Is there another way except for directly modifying the xml file?
Thanks and best regards,
Bart
Op Wed, 22
Jun 2005 16:01:57 -0700, schreef Rima Kanguri:
> Can you attach the report design file.
> Did you set the margins of the master page through the property editor UI ?
> --Thanks
> Rima
> Bart Maertens wrote:
>> page margins.
>> problem.
>> Regards,
>> Bart
FUDForum. Page generated in 0.03775 seconds
