Home » Eclipse Projects » GEF » quick start on implementing own layout
quick start on implementing own layout [message #48279] Fri, 06 December 2002 08:01 Go to next message
I got my model displayed, which all elements placed on each other (all
loaction = (0,0)). My target is to layout my elements on the top edit
part figure, initially as well at user request ("do layout"-button
e.g.). My question is not about layout or routing algorithm but how to
integrate them in GEF.
As far as I understand GEF there should be a layout policy implemented
for the top level edit part under role LAYOUT_ROLE, but which policy and
to and where to implement what hooks? I don't want the algorithm to be
executed evertime an element is added, only initially and on user demand.
At the moment I set the sub elements location when they are created
(ElementEditPart.createFigure()), I want to put this responsibility onto
a layout object.
Chris
Re: quick start on implementing own layout [message #48310 is a reply to message #48279] Fri, 06 December 2002 08:07 Go to previous message
I figured out my task more clearly:
_After_ all the elements are put on the top level I want to layout them.
I could not find a hook for that yet.
Chris
Previous Topic:Using SWT controls as Figure?
Next Topic:Naive question: can I have both a GEF editor and a property editor on the same model?
Current Time: Tue Nov 04 17:18:00 EST 2025
Powered by FUDForum. Page generated in 0.03208 seconds
