Home » Eclipse Projects » Nebula » [grid] column width font size
[grid] column width font size [message #48255] Wed, 30 January 2008 07:12 Go to next message
When I work out the exact width of a font string "test" this size is not
enough when setting the column width to display "test".
Clearly there is some margin being used - how can I programmatically
determine what that margin is (that if the text is bigger it shows a ...
instead)
Grant
Re: [grid] column width font size [message #48284 is a reply to message #48255] Wed, 30 January 2008 07:29 Go to previous message
I found my answer - DefaultCellRenderer has a left and right margin of 4
pixels... would be nice if we could provide a getMargin so that we can
assign widths based on text font size without having to check for
changes in the source.
Grant Slender wrote:
> instead)
> Cheers,
> Grant
Re: [grid] column width font size [message #588225 is a reply to message #48255] Wed, 30 January 2008 07:29 Go to previous message
> instead)
> Cheers,
> Grant
Previous Topic:[grid] column width font size
Next Topic:Some Grid-questions
Current Time: Tue Oct 28 02:28:13 EDT 2025
Powered by FUDForum. Page generated in 0.04307 seconds
