Home » Archived » Test and Performance Tools Platform (TPTP) » just want to test a plug-in
just want to test a plug-in [message #48254] Tue, 27 December 2005 05:54 Go to next message
Originally posted by: address.starts.after.hyphen-martin.umgeher.joanneum.at
Hi all,
I'd like to auto-test some of my custom plug-ins. Most of the code can
be separately tested with simple JUnit test cases, but for some stuff
relying on the eclipse resource framework, JUnit is not enough. Is TPTP
the right tool for this? Note that I don't require performance testing.
monitoring, etc. just simple test cases for classes which use the
eclipse platform. Since I didn't find concrete docs, I'd like to ask
this to the newsgroup.
M
Re: just want to test a plug-in [message #48347 is a reply to message #48254] Tue, 27 December 2005 21:35 Go to previous messageGo to next message
If it's JUnit Plugin testing you're looking after, then look here:
TPTP Tester guide > JUnit testing with TPTP > Testing JUnit Plug-ins with
TPTP
"martin" <address.starts.after.hyphen-martin.umgeher@joanneum.at> wrote in
message news:dor6ga$va4$1@utils.eclipse.org...
> Hi all,
> M
Re: just want to test a plug-in [message #48377 is a reply to message #48347] Wed, 28 December 2005 03:05 Go to previous messageGo to next message
> TPTP
Thanks, that's what I was looking for. Only problem is: I can't follow
the tutorial because my TPTP doesn't add a 'Test/TPTP JUnit Plugin Test'
wizard (though it does add a bunch of other wizards). I use eclipse
3.1.1 and TPTP 4.0.1 (the 'All' download with 28MB). Wrong version for
the tutorial?
Thx,
M
Re: just want to test a plug-in [message #48710 is a reply to message #48377] Sun, 01 January 2006 23:38 Go to previous messageGo to next message
JUnit Plugin test was introduced in TPTP 4.1. You'll need to grab release
4.1 to be able to use this feature.
message news:doth01$e3a$1@utils.eclipse.org...
with
> > TPTP
> the tutorial?
> Thx,
> M
Re: just want to test a plug-in [message #49552 is a reply to message #48710] Mon, 09 January 2006 05:04 Go to previous messageGo to next message
Upgraded to TPTP 4.1, still no 'Test' wizard category and no 'TPTP JUnit
Plugin Test' wizard... what else could be wrong or missing?
M
Re: just want to test a plug-in [message #49702 is a reply to message #49552] Mon, 09 January 2006 18:53 Go to previous messageGo to next message
That's very odd.
Assuming that you've downloaded TPTP (ALL -Runtime/SDK), you should be able
to see the test wizard under:
- File > New > Other > Test
You might be looking for the Test wizard under File > New > Project, which
the wrong place to look.
Do you get the 'Test' perspective? If not, then attach the workspace log
file to this thread. Make sure that you have a number of plugins under
<ECLIPSE-HOME>/plugin with the prefix: org.eclipse.hyades.test.*
What is your OS?
message news:dptcij$b0h$1@utils.eclipse.org...
release
> M
Re: just want to test a plug-in [message #49792 is a reply to message #49702] Tue, 10 January 2006 05:20 Go to previous message
Looking at the log was a brilliant idea... I was missing the XSD
plug-in. Thanks for your help!
M
Previous Topic:Request for Comment: Defect #122770.
Next Topic:Profiling multiple Eclipse web services
Current Time: Fri Nov 07 05:49:16 EST 2025
Powered by FUDForum. Page generated in 0.04139 seconds
