Home » Modeling » TMF (Xtext) » using xtext editors in a Rich Client
using xtext editors in a Rich Client [message #48223] Thu, 04 June 2009 16:28 Go to next message
I ahve a trivial editor and I am trying to make it work inside a RCP. I have
impl'd other text editors inside the RCP but the xtext xtext editor just
opens with a split pane and the word ERROR in the bottom pane. I am passing
a custom IPathEditorInput to the open editor call, put maybe I need a
different editorInput to make this work?
IPath location= new Path(file.getAbsolutePath());
PathEditorInput input= new PathEditorInput(location);
IWorkbenchPage page=
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
IEditorPart thePart=page.openEditor(input, editorId);
public class PathEditorInput implements IPathEditorInput
Re: using xtext editors in a Rich Client [message #58380 is a reply to message #48223] Tue, 14 July 2009 08:55 Go to previous messageGo to next message
Originally posted by: c.krause.cwi.nl
Hi Drew,
I encounter the same problem. Did you finally get it working somehow?
Christian
Re: using xtext editors in a Rich Client [message #58436 is a reply to message #58380] Tue, 14 July 2009 10:18 Go to previous message
I've recently filed an issue about this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283086
Previous Topic:[Xtext] ANTLR options
Next Topic:No getter or adder for 'genmodels' (EcoreGeneratorFragment)
Current Time: Thu Nov 06 23:51:42 EST 2025
Powered by FUDForum. Page generated in 0.04330 seconds
