| how do i get net4j? [message #48198] |
Thu, 31 August 2006 15:50  |
Originally posted by: liam.morley.baesystems.com
I'm using the update manager site found at
http://download.eclipse.org/technology/emft/updates/site-int erim.xml, and
when I select "org.eclipse.net4j.sdk", it says that it declares a dependency
on "org.eclipse.net4j" which it can't find. I've tried the "Select Required"
button as well as installing "org.eclipse.net4j" first, but nothing seems to
work.
I looked at org.eclipse.net4j, and apparently there is no org.eclipse.net4j
plugin- just the feature. Does the sdk declare a dependency on a plugin or a
feature? Is it possible to declare a dependency on a feature? How do I get
this up and running?
Thanks all-
Liam Morley
FUDForum. Page generated in 0.03902 seconds
