Home » Eclipse Projects » Subversive » Compare with options disabled on folders
Compare with options disabled on folders [message #47986] Mon, 29 June 2009 10:23 Go to next message
Originally posted by: b_apolci.libero.it
The Compare with menu has all the option disabled (greyed out) on
folders and project, with the exception "Base for working copy".
Here are the versions of what I've installed on top of Eclipse Java EE 3.5:
Subversive SVN JDT Ignore Extensions (Optional) (Incubation)
0.7.8.I20090506-1500
org.eclipse.team.svn.resource.ignore.rules.jdt.feature.group
Subversive SVN Team Provider (Incubation) 0.7.8.I20090506-1500
org.eclipse.team.svn.feature.group
SVNKit 1.3.0 Implementation (Optional) 2.2.0.I20090505-1500
org.polarion.eclipse.team.svn.connector.svnkit16.feature.gro up
Subversive SVN Connectors 2.2.0.I20090505-1500
org.polarion.eclipse.team.svn.connector.feature.group
Re: Compare with options disabled on folders [message #48046 is a reply to message #47986] Fri, 03 July 2009 06:36 Go to previous messageGo to next message
Am I the only one with this problem?
I tried also to do a clean install of eclipse and the problem is still
there.
I tried with both SVNKit and JavaHL connectors.
Thanks for any help,
Andrea
Re: Compare with options disabled on folders [message #48076 is a reply to message #48046] Fri, 03 July 2009 09:13 Go to previous messageGo to next message
Hello Andrea,
This problem is already fixed, for more details please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=275287. It's fixed in weekly
build.
> there.
> Andrea
>> The Compare with menu has all the option disabled (greyed out) on folders
>> 3.5:
Re: Compare with options disabled on folders [message #48136 is a reply to message #48076] Fri, 03 July 2009 09:33 Go to previous message
Igor Burilo ha scritto:
> Hello Andrea,
> build.
I installed the weekly build and now the comparison work fine.
Thank you
Andrea
Previous Topic:New Merge dialog?
Next Topic:Subversive connectors discovery
Current Time: Sun Nov 23 20:46:47 EST 2025
Powered by FUDForum. Page generated in 0.05850 seconds
