Home » Archived » XML Schema Definition (XSD) » Element validation
Element validation [message #47943] Fri, 18 June 2004 02:39 Go to next message
Originally posted by: invalid.soft-gems.net
Hi Ed,
Thanks to your help my schema based editor runs now excellently. Attribute
assessment works also fine, but now I want to validate an entire element.
Since there is nothing like assess for an element declaration I wonder if
it is possible at all to let the XSD package validate an element. Can you
help again, please?
Mike
www.soft-gems.net
Re: Element validation [message #47975 is a reply to message #47943] Fri, 18 June 2004 05:06 Go to previous messageGo to next message
Mike,
No, unfortunately I've never had the time to do assessment for elements. It's
a fairly big piece of work, although some parts of it would be pretty easy to
do. E.g., using the particle's DFA to validate the elements and using the
attribute uses to validate the attributes...
Mike Lischke wrote:
> Hi Ed,
> help again, please?
> Mike
> www.soft-gems.net
Re: Element validation [message #48005 is a reply to message #47975] Fri, 18 June 2004 06:21 Go to previous message
It's
That's a pity. It really would ease my task a lot and it would allow to do
revalidation of documents in memory, while currently you can validate a
document only when creating/loading it.
Mike
www.soft-gems.net
Re: Element validation [message #589342 is a reply to message #47943] Fri, 18 June 2004 05:06 Go to previous message
Mike,
Mike Lischke wrote:
> Hi Ed,
> help again, please?
> Mike
> www.soft-gems.net
Re: Element validation [message #589357 is a reply to message #47975] Fri, 18 June 2004 06:21 Go to previous message
It's
Mike
www.soft-gems.net
Previous Topic:Element validation
Next Topic:XPATH
Current Time: Wed Nov 05 22:12:37 EST 2025
Powered by FUDForum. Page generated in 0.26110 seconds
