Home » Modeling » OCL » collection(T2)
collection(T2) [message #47882] Fri, 11 January 2008 06:26 Go to next message
Originally posted by: krzysztof_kaczmarski.o2.pl
Hi All,
could somebody please explain me why in the OCL standard library
defined in MDT-OCL collect() operation returns result of type
collection(T2)?
I understand that collection(T2) indicates that its elements are of
different type than in the original collection(T).
I cannot perform any operation on the collect() resulting collection
(like for example collect(x)->sum() because in the standard library
collection(T2) has no operations defined.
Thanks in advance,
Krzysztof
Re: collection(T2) [message #47974 is a reply to message #47882] Fri, 11 January 2008 08:50 Go to previous messageGo to next message
Hi, Krzysztof,
The T2 type in the stdlib implementation is a somewhat clumsy way to
represent the template parameter T2 in the OCL Specification's definition
of the collect() iterator.
Collection(T2) doesn't have to define operations of its own because it
inherits them from the basic Collection definition. How are you attempting
to parse/evaluate your expression? I have no difficult with expressions
such as
EClassifier.allInstances()->collect(name)->collect(size())- >sum()
Christian
Krzysztof Kaczmarski wrote:
> Hi All,
> collection(T2)?
> Thanks in advance,
> Krzysztof
Re: collection(T2) [message #48034 is a reply to message #47974] Fri, 11 January 2008 09:02 Go to previous messageGo to next message
Hi Christian,
is this inheritance defied in oclstdlib.uml ?
I cannot see that.
Krzysztof
Christian W. Damus wrote:
> Hi, Krzysztof,
> such as
> Cheers,
> Christian
>> Hi All,
>> collection(T2)?
>> Thanks in advance,
>> Krzysztof
Re: collection(T2) [message #48123 is a reply to message #48034] Fri, 11 January 2008 13:16 Go to previous messageGo to next message
Hi, Krzysztof,
This is one of the peculiarities of the oclstdlib.{ecore,uml}
implementations, that these generalization relationships are not defined in
the library models, but instead are implemented in code. Ecore cannot
express generalizations between non-EClasses, and this structure was
reproduced in the UML representation because of the way that the parser
internally supplies the inheritance. This is one of several aspects of
these libraries that needs to be cleaned up in an eventual MDT OCL 2.0
release ...
Christian
> Hi Christian,
> I cannot see that.
> Cheers,
> Krzysztof
>> Hi, Krzysztof,
>> attempting
>> such as
>> Cheers,
>> Christian
-----8<-----
Re: collection(T2) [message #48154 is a reply to message #48123] Sat, 12 January 2008 03:55 Go to previous message
Oh, so my own implementation of OCL will have to implement it
implicitly too.
Thanks for this clarification.
Krzysztof
> Hi, Krzysztof,
> release ...
> Cheers,
> Christian
>> Hi Christian,
>> I cannot see that.
>> Cheers,
>> Krzysztof
>>> Hi, Krzysztof,
>>> attempting
>>> such as
>>> Cheers,
>>> Christian
> -----8<-----
Previous Topic:custom PrimitiveType literals
Next Topic:Global Operations
Current Time: Sat Nov 08 00:31:39 EST 2025
Powered by FUDForum. Page generated in 0.03632 seconds
