Home » Language IDEs » C / C++ IDE (CDT) » CDT process spawner
CDT process spawner [message #47808] Tue, 29 October 2002 00:32 Go to next message
Originally posted by: g.wagenknecht.planet-wagenknecht.de
Hi!
I noticed that the CDT uses an own spawner with native libraries. Was it
because of limitations of the different Java VMs? Is it possible to use this
spawner in other projects?
Cu, Gunnar
Re: CDT process spawner [message #47928 is a reply to message #47808] Wed, 30 October 2002 08:34 Go to previous message
Gunnar Wagenknecht wrote:
> Hi!
The spawner has methods to interrupt a process (currently used by the gdb/mi debugger),
also with a 1.3 VM on win32 it will surpress the DOS console which normally pops up for
every Runtime.exec().
> Is it possible to use this spawner in other projects?
Sure, the only possible issue is that you will have a cdt.core dependency, but if your
plugin is a cdt extension or tool then I guess it doesn't matter.
Dave.
> Cu, Gunnar
Previous Topic:C-Build make
Next Topic:CProjectWizard Question
Current Time: Mon Jul 14 07:48:13 EDT 2025
Powered by FUDForum. Page generated in 0.05907 seconds
