Home » Modeling » M2T (model-to-text transformation) » iteration over an iterable object not a select
iteration over an iterable object not a select [message #47735] Wed, 16 July 2008 12:24 Go to next message
I am loading multiple input files into a big input tree
I resorted to do a <c:load ...> inside a scriptlet loop
but I'd been happier if I could do a
<c:iterate ..>
where instead of an xpath select i could pass a {$variable} that is of
an iterable type (eg a String[] or a Set<String> ) ecc.
Re: iteration over an iterable object not a select [message #47764 is a reply to message #47735] Wed, 16 July 2008 14:26 Go to previous messageGo to next message
Edoardo:
Please submit an enhancement.
https://bugs.eclipse.org/bugs/enter_bug.cgi?assigned_to=peld er%40ca.ibm.com&blocked=&bug_file_loc=http%3A%2F%2F& amp;bug_severity=enhancement&bug_status=NEW&comment= &component=Jet&contenttypeentry=&contenttypemeth od=autodetect&contenttypeselection=text%2Fplain&data =&dependson=&description=&flag_type-1=X&flag _type-2=X&flag_type-4=X&flag_type-6=X&flag_type- 7=X&flag_type-8=X&form_name=enter_bug&keywords=& amp;maketemplate=Remember%20values%20as%20bookmarkable%20tem plate&op_sys=Windows%20XP&priority=P3&product=M2 T&qa_contact=&rep_platform=PC&short_desc=&ve rsion=unspecified
In the meantime, it is not hard to build a custom tag.
Paul
"Edoardo Comar" <ecomar@uk.ibm.com> wrote in message
news:g5l7bc$bjm$1@build.eclipse.org...
> <c:iterate ..>
> where instead of an xpath select i could pass a {$variable} that is of an
Re: iteration over an iterable object not a select [message #47818 is a reply to message #47764] Thu, 17 July 2008 05:48 Go to previous messageGo to next message
but it is even easier to use scriptlets :-)
Re: iteration over an iterable object not a select [message #47848 is a reply to message #47764] Thu, 17 July 2008 05:52 Go to previous message
done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241220
Paul Elder wrote:
> Edoardo:
> Paul
>> <c:iterate ..>
Previous Topic:How to set the transformation output file path?
Next Topic:[MOFScript] Problem with metamodel setting in Java integration
Current Time: Wed Nov 05 17:30:54 EST 2025
Powered by FUDForum. Page generated in 0.03650 seconds
