Home » Eclipse Projects » GEF » Should interfaces be prefixed with I?
Should interfaces be prefixed with I? [message #47701] Thu, 05 December 2002 09:03 Go to next message
After some programming with the Eclipse SDK, I kind of like the
convention to begin interface names with an uppercase I - as in
"IStatus" - together with an implementation "class Status implements
IStatus".
With the exception of IFigure, it seems, that GEF doesn't follow this
convention. Implementations of interfaces XXX are some times called
XXImpl, sometimes DefaultXXX, often there're prefixed with a project
specific prefix LogicXXX. Was there any reason not to follow the
eclipse conventions (other than historical ones)?
It's probably too late now, but I wished, it would be changed.
bye
Stefan Matthias Aust
www.3plus4software.de // Inter Deum Et Diabolum Semper Musica Est
Re: Should interfaces be prefixed with I? [message #47916 is a reply to message #47701] Thu, 05 December 2002 15:42 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
We are trying to follow the Java coding standards. I would like to avoid
IFigure, but then I couldn't decide what to call the default implementation.
We have had suggestions to completely remove interfaces for Figure and
EditPart. What do you think?
We plan to delete all of the PaletteXxx interfaces, and rename the classes
to the interface names.
originally, Draw2d only required SWT, and SWT does not use I prefix for
interfaces.
"Stefan Matthias Aust" <sma@3plus4.de> wrote in message
news:asnlun$nmd$2@rogue.oti.com...
> IStatus".
> bye
Previous Topic:Connection anchors to an emulated draw2d list of labels?
Next Topic:How to limit edit part size for resizing?
Current Time: Wed Oct 22 16:07:21 EDT 2025
Powered by FUDForum. Page generated in 0.04301 seconds
