Home » Eclipse Projects » Plugin Development Environment (PDE) » Compiler warnings during headless build
Compiler warnings during headless build [message #47699] Fri, 20 February 2009 07:00 Go to next message
Hello all,
I have the following problem:
When compiling projects locally I can influence (through workspace
preferences) how many and of which type warnings are created by Eclipse
(e.g. create warning for missing javadoc).
When building these projects in a headless build I get a different set of
warnings for the same project.
How can I transfer the compiler warning preferences to the headless build
so that I get the same warnings?
Kind regards Marko T.
Re: Compiler warnings during headless build [message #47798 is a reply to message #47699] Mon, 23 February 2009 09:47 Go to previous messageGo to next message
Individual plugins can set what compiler warnings to use with the
"javacWarnings.<library>" property. (<library> is the library being
built: javacWarnings.. or javacWarnings.library.jar)
There is some small detail here:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/reference/pde_feature_generating_build.htm
You can also set compiler options for all plugins using the
"compilerArg" property in your main build configuration.
-Andrew
Marko Tomljenovic wrote:
> Hello all,
> of warnings for the same project.
> build so that I get the same warnings?
Re: Compiler warnings during headless build [message #47893 is a reply to message #47798] Tue, 24 February 2009 03:44 Go to previous message
thanks for the quick answer. This already helps me a lot.
But I can't find any fine granular settings for the javadoc warnings!
Does anybody know how the javadoc settings are handed over to the jdt
compiler (if at all)?
Because I can store the settings project specifically by I guess the PDE
build doesn't care about those settings.
Greetings Marko
Re: Compiler warnings during headless build [message #592246 is a reply to message #47699] Mon, 23 February 2009 09:47 Go to previous message
-Andrew
> Hello all,
Re: Compiler warnings during headless build [message #592281 is a reply to message #47798] Tue, 24 February 2009 03:44 Go to previous message
Greetings Marko
Previous Topic:Custom target platform layout
Next Topic:Is there possible to programmatically change the target platform of a workspace?
Current Time: Thu Nov 20 06:27:49 EST 2025
Powered by FUDForum. Page generated in 0.03842 seconds
