Home » Modeling » GMF (Graphical Modeling Framework) » Problem with TreeEditPart in DiagramOutlinePage: Not showing children nodes
Problem with TreeEditPart in DiagramOutlinePage: Not showing children nodes [message #47664] Thu, 14 September 2006 02:56 Go to next message
Whenever we select the tree viewer icon in outlinepage, it displays only the
first-level nodes placed on diagram.
It does not show the nodes within a composite node.
As we can't override DiagramOutlinePage we are not sure if TreeEditPart is
working properly.
Can anyone point out what's going wrong here ?
~ Kaniska
Re: Problem with TreeEditPart in DiagramOutlinePage: Not showing children nodes [message #48411 is a reply to message #47664] Thu, 14 September 2006 23:25 Go to previous messageGo to next message
You may want to check this out:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=142957
Li
Re: Problem with TreeEditPart in DiagramOutlinePage: Not showing children nodes [message #49042 is a reply to message #47664] Fri, 15 September 2006 11:48 Go to previous message
Originally posted by: vcciubot.uwaterloo.ca
If I remember correctly you have to override some methods in in
AbstractTreeEditPart - look somewhere in the editor hierarchy to see which
class generates the outline viewer.
Currently no children are added by that edit part.
vlad
On Thu, 14 Sep 2006 12:26:17 +0530, Kaniska wrote:
> working properly.
> ~ Kaniska
Previous Topic:Can not view .ecore_diagram in editor but see in outline
Next Topic:multiple CommandStack with an unique EditingDomain
Current Time: Thu Jul 17 19:56:04 EDT 2025
Powered by FUDForum. Page generated in 0.06878 seconds
