| Model-To-Text-Language (MTL) Implementation [message #47648] |
Wed, 16 July 2008 08:04  |
Hi all,
yesterday, i've read the MTL-Spec from the OMG, which seems to be a good try
for a one-in-all solution for code generation. According to the roadmap of
the M2T-Project and complete implementation of the spec will be published in
June 2009. Is it possible to volunteer myself for testing an early alpha
version of the project, when it is released? I'm very interesting in this
implementation.
Greetings
Timothy
| Re: Model-To-Text-Language (MTL) Implementation [message #47908 is a reply to message #47878] |
Thu, 17 July 2008 09:12   |
Of course, it will be a public version
Timothy Marc a écrit :
> Dear Jonathan,
> thank you for your answer. I think, i will have the time to wait for the
> build of the first version. Is that early version available for anyone, or
> just for project members?
> Thx
> --Timothy
> "Jonathan MUSSET" <jonathan.musset@obeo.fr> schrieb im Newsbeitrag
> news:487E0D1B.3060504@obeo.fr...
>> We will build a first version in the next few weeks (august)
>> but you can try to checkout the following projects
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.engi ne "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.ide. ui "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.mode l "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.pars er "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.comm on "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl-feat ure "
>> Host : dev.eclipse.org
>> Repository Path : /cvsroot/modeling
>> You need to install MDT OCL plugin
>> You have examples in "*.tests" projects
>> You can search "*.mtl" files
>> A Java File, and 2 ANT files are automatically created when you compile a
>> template that contains a "[file...]" block
>> You just have to rename the "*.sample" file (-> "generate.xml" for
>> example)
>> Put it in the target project and call it with "External Tools > Run As >
>> Ant Build"
>> You have to change the "MODEL" and the "TARGET" values
>> At the moment, you need to refresh the workspace at the end of the
>> generation
>> Regards,
>> Jonathan Musset
>>> Hi all,
>>> try for a one-in-all solution for code generation. According to the
>>> roadmap of the M2T-Project and complete implementation of the spec will
>>> be published in June 2009. Is it possible to volunteer myself for testing
>>> an early alpha version of the project, when it is released? I'm very
>>> interesting in this implementation.
>>> Greetings
>>> Timothy
| Re: Model-To-Text-Language (MTL) Implementation [message #48496 is a reply to message #47908] |
Mon, 11 August 2008 03:58  |
You can get the last build on the website (I200808081155) :
http://www.eclipse.org/modeling/m2t/downloads/?project=mtl
Jonathan
>> Dear Jonathan,
>> the build of the first version. Is that early version available for
>> anyone, or just for project members?
>> Thx
>> --Timothy
>>> Hi,
>>> compile a template that contains a "[file...]" block
>>> example)
>>> As > Ant Build"
>>> generation
>>> Regards,
>>> Jonathan Musset
>>>> Hi all,
>>>> good try for a one-in-all solution for code generation. According to
>>>> the roadmap of the M2T-Project and complete implementation of the
>>>> spec will be published in June 2009. Is it possible to volunteer
>>>> myself for testing an early alpha version of the project, when it is
>>>> released? I'm very interesting in this implementation.
>>>> Greetings
>>>> Timothy
FUDForum. Page generated in 0.04397 seconds
