Re: How to write Feature Value spec body in java if it is supported [message #47794 is a reply to message #47633] |
Thu, 14 September 2006 05:08   |
Hi Junyan,
In case of 'java' language, the body does not define a java implementation,
but expects an identifier, which will be used
to derive the real name of corresponding java skeleton method in the
generated code. The custom java implementation is
to be provided by the user in the generated skeleton.
FYI, we will add support for pure Java initializer of domain elements soon,
in order to eliminate the per-feature partitioning
of the initialization logic for Java. This should help in simplification of
writing a complex init code.
/Radek
"Junyan" <alexmajy@gmail.com> wrote in message
news:ff353b398c9d4943dec6a76579a598bb$1@www.eclipse.org...
> Dose anyone know how to write the body of the "Feature Value spec" in java
> if it is supported? If not, where should I go to add my own code inialize?
> Or is there any more detailed document about it? Thanks for advance.
> best regards
> Junyan
Re: How to write Feature Value spec body in java if it is supported [message #48126 is a reply to message #47794] |
Thu, 14 September 2006 11:10  |
Radek Dvorak wrote:
> Hi Junyan,
> /Radek
>> best regards
>> Junyan
Thank you Radek
FUDForum. Page generated in 0.05735 seconds
