Home » Modeling » GMF (Graphical Modeling Framework) » How to write Feature Value spec body in java if it is supported
How to write Feature Value spec body in java if it is supported [message #47633] Thu, 14 September 2006 00:29 Go to next message
Dose anyone know how to write the body of the "Feature Value spec" in java
if it is supported? If not, where should I go to add my own code inialize?
Or is there any more detailed document about it? Thanks for advance.
best regards
Junyan
Re: How to write Feature Value spec body in java if it is supported [message #47794 is a reply to message #47633] Thu, 14 September 2006 05:08 Go to previous messageGo to next message
Hi Junyan,
In case of 'java' language, the body does not define a java implementation,
but expects an identifier, which will be used
to derive the real name of corresponding java skeleton method in the
generated code. The custom java implementation is
to be provided by the user in the generated skeleton.
FYI, we will add support for pure Java initializer of domain elements soon,
in order to eliminate the per-feature partitioning
of the initialization logic for Java. This should help in simplification of
writing a complex init code.
/Radek
"Junyan" <alexmajy@gmail.com> wrote in message
news:ff353b398c9d4943dec6a76579a598bb$1@www.eclipse.org...
> best regards
> Junyan
Re: How to write Feature Value spec body in java if it is supported [message #48126 is a reply to message #47794] Thu, 14 September 2006 11:10 Go to previous message
Radek Dvorak wrote:
> Hi Junyan,
> /Radek
>> best regards
>> Junyan
Thank you Radek
Previous Topic:can domain model updates drive graphical definition model updates?
Next Topic:Layout for Canvas
Current Time: Fri Sep 12 22:16:28 EDT 2025
Powered by FUDForum. Page generated in 0.05420 seconds
