Home » Eclipse Projects » DTP » [ODA Ecore] Integration and Deployment Questions
| [ODA Ecore] Integration and Deployment Questions [message #47526] |
Tue, 22 July 2008 18:22  |
Originally posted by: jconlon.apache.org
Have successfully tested launching the ODA Ecore with an Ecore model
instance by following the Getting Started Guide in:
http://timezra.blogspot.com/2008/04/oda-ecore-getting-starte d-guide.html
Have a couple questions regarding the next steps I need to take
regarding offering BIRT functionality to ECore enabled RCP Products.
RCP Product Integration?
To allow users of an RCP Product to design and render BIRT reports from
registered Ecore model instances, I expect (I'm a BIRT newbie) one will
need to integrate and build the ODA Ecore and BIRT functionality with a
branded RCP Product.
Attempting to do so, I have added ODA Ecore, BIRT Designer & Runtime
features and their dependent features to an existing RCP Product. While
it was a tedious process to identify all the needed dependencies for
BIRT, I finally got it working. Unfortunately the dependencies were
non-trivial and my RCP product gained a lot of weight in the process. A
good part of the added weight was that I needed to pull in the JDT and
PDE to get the BIRT designer and the Report Design Perspective.
Is there a less bulky way to do this? (ie - any alternative scenarios
that have been tested without all the overhead of JDT and PDE)
JEE Deployment:
When Birt reports are using ODA Ecore DataSources I know the user of an
Integrated RCP Product (like the one I built above) can, from within the
Navigator View, render the report for printing or export with the
Report>Run Report to bring up the BIRT Report Viewer. But what about
reports that are deployed to a BIRT enableed JEE server? Haven't tried
this but I expect that the BIRT War needs to know something about my
registered models.
What do I need to add to a tomcat server (for example) to enable the
Birt War to work with my particular models?
thanks,
John
| Re: [ODA Ecore] Integration and Deployment Questions [message #47620 is a reply to message #47526] |
Wed, 23 July 2008 18:45   |
John,
This seems to be more a BIRT newsgroup posting. Cross posting there for the
intended audience.
RE: using BIRT designer in a RCP appl, BIRT has pre-packaged all its needed
dependencies as a RCP appl. See "RCP Designer" in BIRT download page:
http://download.eclipse.org/birt/downloads/
That should provide you the list of minimal plugins that are needed to
include BIRT designer in your existing RCP product.
This FAQ page may also have the info you are looking for:
http://wiki.eclipse.org/BIRT/FAQ/Deployment .
In general, you can simply include the oda.ecore runtime plugin to the BIRT
web appl (under WEB-INF/platform/plugins) for it to be visible as an ODA
data source to the BIRT engine.
Linda
"John E. Conlon" <jconlon@apache.org> wrote in message
news:g65mid$540$1@build.eclipse.org...
> Have a couple questions regarding the next steps I need to take regarding
> it was a tedious process to identify all the needed dependencies for BIRT,
> I finally got it working. Unfortunately the dependencies were non-trivial
> and my RCP product gained a lot of weight in the process. A good part of
> the added weight was that I needed to pull in the JDT and PDE to get the
> Is there a less bulky way to do this? (ie - any alternative scenarios that
> JEE Deployment:
> registered models.
> What do I need to add to a tomcat server (for example) to enable the Birt
> thanks,
> John
| Re: [ODA Ecore] Integration and Deployment Questions [message #47749 is a reply to message #47620] |
Thu, 24 July 2008 16:48   |
Linda,
See comments below.
Linda Chan wrote:
> John,
> intended audience.
Makes sense.
I suspect, but am not sure, that the Ecore model plugin (generated from
the model .ecore file) may also have to be in the
WEB-INF/platform/plugins directory for BIRT and the ECore ODA to
recognize the registered model ID of the serialized model instance.
Have BIRT JEE deployment scenarios been tested with the ECore ODA?
John
> Linda
>> JEE Deployment:
>> registered models.
>> thanks,
>> John
| Re: [ODA Ecore] Integration and Deployment Questions [message #47779 is a reply to message #47749] |
Fri, 25 July 2008 19:02  |
> the model .ecore file) may also have to be in the WEB-INF/platform/plugins
> directory for BIRT and the ECore ODA to recognize the registered model ID
Yes, naturally any plugin dependencies need to be included as well.
Well, we welcome the community to test it and let us all know. The ECore
ODA driver is in incubation, and has yet to provide its downloadable plugin
jars. It would need more community contribution at this stage.
Linda
| Re: [ODA Ecore] Integration and Deployment Questions [message #592194 is a reply to message #47526] |
John,
intended audience.
Linda
> JEE Deployment:
> registered models.
> thanks,
> John
| Re: [ODA Ecore] Integration and Deployment Questions [message #592255 is a reply to message #47620] |
Linda,
See comments below.
Linda Chan wrote:
> John,
> intended audience.
Makes sense.
John
> Linda
>> JEE Deployment:
>> registered models.
>> thanks,
>> John
| Re: [ODA Ecore] Integration and Deployment Questions [message #592261 is a reply to message #47749] |
Linda
Current Time: Thu Nov 06 03:40:18 EST 2025
Powered by FUDForum. Page generated in 0.09607 seconds
