Home » Eclipse Projects » Subversive » Error: unable connect...
Error: unable connect... [message #47487] Thu, 18 June 2009 03:09 Go to next message
Originally posted by: antispam.domain.invalid
While launching my Eclipse (3.4.1) this morning, I got this error message:
> SVN: '0x00000000: Open Project' operation finished with error: 0x00000000: Unable connect to 'xxxx' project.
> Please check that SVN meta-information exists and its format is supported by the current SVN plug-in version.
> If so, it is possible that project working copy is relocated outside plug-in control.
> At the current moment project will be automatically disconnected from source control.
Now my projects are no more available in SVN perspective...
What should I do now?
Thanks in advance.
Patrick
Re: Error: unable connect... [message #47548 is a reply to message #47487] Thu, 18 June 2009 12:47 Go to previous messageGo to next message
Patrick,
Try right clicking on a project that was connected, go to Team -> Share
Project, select SVN (as opposed to CVS), and see if the wizard that
comes up will allow you to reconnect your project(s).
Patrick Godeau wrote:
> Hello,
> Thanks in advance.
Re: Error: unable connect... [message #47663 is a reply to message #47548] Mon, 22 June 2009 05:55 Go to previous messageGo to next message
Le 18/06/2009 18:47, Joseph Gay a écrit :
> Patrick,
I tried this but it says:
"This wizard will help you to share your files with the SVN repository
for the first time."
This is not what would be expected.
Any idea?
>> Hello,
>> message:
>>> plug-in control.
>>> source control.
>> Thanks in advance.
Re: Error: unable connect... [message #47721 is a reply to message #47663] Mon, 22 June 2009 12:49 Go to previous messageGo to next message
Patrick,
There should also be an option there to use an existing repository
location. I've successfully used this in the past to reconnect projects
that were previously connected.
>> Patrick,
> Any idea?
>>> Hello,
>>> message:
>>>> plug-in control.
>>>> source control.
>>> Thanks in advance.
Re: Error: unable connect... [message #47810 is a reply to message #47721] Thu, 25 June 2009 04:06 Go to previous message
I solved this problem by changing the SVN connector to SVN Kit SVN/1.6.1.
>>>> message:
>>>>> plug-in control.
>>>>> source control.
Previous Topic:Can not select JavaHL 1.6 Connector
Next Topic:Subversive is 'mutating' .svn files to higher revision, breaking other clients
Current Time: Sat Nov 08 14:31:34 EST 2025
Powered by FUDForum. Page generated in 0.04251 seconds
