Home » Language IDEs » Java Development Tools (JDT) » code assistant / imports / documentation
code assistant / imports / documentation [message #47480] Tue, 03 June 2003 11:48 Go to next message
Hi all
I'm new to eclipse. So far I've been using JBuilder for years.
Is there a way to tell the code assistant (popup with methods) to mark
deprecated methods?
A compiler warning tells me that one of the methods I'm trying to use is
deprected. In JBuilder I had a context menu that allowed me to immediately
open the JavaDoc documentation for the particular class (look up deprecation
hint). How do I do that with eclipse?
Do you know of a plugin that converts
import java.util.List;
import java.util.DateFormat;
style import statements to
import java.util.*;
Thanks for your help
Marcel
Re: code assistant / imports / documentation [message #47540 is a reply to message #47480] Tue, 03 June 2003 12:07 Go to previous messageGo to next message
Originally posted by: faust.acm.org
1st issue: Go to Window->preferences->compiler->problems tab. Change "usage
of deprecated API" option.
2nd issue: Organize imports under Source menu is your friend (Ctrl-Shift-O).
Would you like an unorganize imports option? ;)
Randy
"Marcel St
Re: code assistant / imports / documentation [message #47698 is a reply to message #47540] Tue, 03 June 2003 13:39 Go to previous messageGo to next message
Thanks for the reply. You didn't really answer my questions, though... ;-)
> "usage of deprecated API" option.
I don't wanna get rid of the deprecated warning - I want to improve my cody
by replacing the deprected method. eclipse is supposed to help me find the
right method.
> (Ctrl-Shift-O). Would you like an unorganize imports option? ;)
I know that option. It's not about beeing organized/sorted or not. I want to
have as little import statements as possible. This can be achieved through
massive use of .* imports.
>> Hi all
>> mark deprecated methods?
>> use is deprected. In JBuilder I had a context menu that allowed me
>> to immediately open the JavaDoc documentation for the particular
>> class (look up deprecation hint). How do I do that with eclipse?
>> import java.util.*;
Marcel
Re: code assistant / imports / documentation [message #47728 is a reply to message #47698] Tue, 03 June 2003 14:09 Go to previous messageGo to next message
Well, if you use Ctrl+Space for auto completion, deprecated methods have
a yellow warning sign by them. If you then highlight the method in your
code and press F1, you can select "Javadoc for <method>" to see the javadoc.
"massive use of .* imports" is generally considered a poor practice by
most programmers (see section titled "Import on demand is pure,
unadulterated EVIL" at http://www.javadude.com/tools/importifier/ for
some reasons), so if you want that functionality, you will probably have
to write the plugin yourself.
> right method.
>>>Hi all
>>>import java.util.*;
> Marcel
Re: code assistant / imports / documentation [message #47760 is a reply to message #47480] Tue, 03 June 2003 14:06 Go to previous messageGo to next message
Marcel Stör wrote:
> Hi all
> deprecated methods?
Deprecated methods are marked with an exclamation mark icon in the Code
Assist popup.
Click on the class name and press Shift-F2 (Open External Javadoc).
> import java.util.*;
Window > Preferences > Java > Organize Imports > "Number of imports
needed for .*".
Hope this helps,
Jeff
Re: code assistant / imports / documentation [message #47849 is a reply to message #47480] Tue, 03 June 2003 16:50 Go to previous messageGo to next message
> import java.util.*;
why would you do that?
first you don't have to be bothered by the imports
because you can use the outline of eclipse that shields
the imports very nicely.
second * imports are very bad things.
You can make code with it that suddenly don't compile anymore
when upgrading to a newer JDK, this should be avoided.
johan
Re: code assistant / imports / documentation [message #48268 is a reply to message #47849] Wed, 04 June 2003 02:10 Go to previous messageGo to next message
>> import java.util.*;
Because I hate list of dozens of import statements!
That sounds real nice! How can I set this up?
Yeah, I'm fully aware of that!
Marcel
Re: code assistant / imports / documentation [message #48471 is a reply to message #47698] Wed, 04 June 2003 05:32 Go to previous messageGo to next message
I see. So you want a refactoring for replacing deprecated methods. And you'd
like obvious candidates to be offered as replacement suggestions or happen
automatically or something along those lines. Enter a bug report with an
enhancement request.
Randy
"Marcel St
Re: code assistant / imports / documentation [message #49035 is a reply to message #48268] Wed, 04 June 2003 13:28 Go to previous messageGo to next message
Using the Outliner to navigate your source will
make you 'jump' over import statements. There is
also a button in the toolbar which let you 'show the
source of the selected element only' (Tooltip).
So using the outliner makes you 'ignore/hide' the
import part (Its still there but you wont see it that
often).
Currently there is no way to colapse the import
part of a source, but as far as I learned, this is
part of the feature list of Eclipse 3.0 currently in
development.
Hope it was understandable ;)
Martin (Kersten)
Re: code assistant / imports / documentation [message #49182 is a reply to message #48471] Wed, 04 June 2003 16:58 Go to previous messageGo to next message
How should that work? Replacements are often poorly documented.
But sth. like a migration tool with replace all calls of method abc()
for type XYZ with a call efg(), or similar, could be helpful in those
situations.
martin
Re: code assistant / imports / documentation [message #49447 is a reply to message #49182] Wed, 04 June 2003 19:10 Go to previous message
Agreed, it might be a dubious enhancement. But I can imagine something like
a migration tool which could take advantage of the new refactoring
particpants story to do a refactor rename based on a set of migration rules.
Randy
"Martin M
Previous Topic:Checkstyle plugins
Next Topic:Updating The Outline View
Current Time: Thu Nov 20 23:51:47 EST 2025
Powered by FUDForum. Page generated in 0.06164 seconds
