| Session Issues [message #47371] |
Mon, 17 September 2007 13:51  |
Hello, with latest changes about session behaviour, sometimes, when I
change between entrypoints this error appears on console (This problem
also occurs in DEMO App, changing between /tea and /rap servlets ):
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:704)
at org.eclipse.swt.SWT.error(SWT.java:650)
at org.eclipse.swt.SWT.error(SWT.java:646)
at org.eclipse.swt.widgets.Widget.error(Widget.java:725)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:557)
at org.eclipse.jface.window.Window.close(Window.java:321)
I'm not sure about what is the correct way to manage session, should I
invalidate it when workbench is closed ? how ?
I'm using a class that extends from SessionSingletonBase, How can I
remove it from SessionStore ?
Regards.
Roberto.
| Re: Session Issues [message #47521 is a reply to message #47461] |
Tue, 18 September 2007 03:17  |
Hi Frank, this is the exact StackTrace, I got reproduce it when I call
/rap and then /rap=startup=controls:
org.eclipse.jface.window.ApplicationWindow.close(Application Window.java:287)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1512)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:610)
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:586)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:701)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:699)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:106)
at org.eclipse.ui.internal.Workbench$10.run(Workbench.java:830)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:8 27)
at org.eclipse.ui.internal.Workbench.access$6(Workbench.java:75 1)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1010 )
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1008)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:979)
at org.eclipse.ui.internal.Workbench$2.run(Workbench.java:93)
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 409)
org.eclipse.ui.internal.Workbench$ShutdownHandler.beforeDest roy(Workbench.java:97)
org.eclipse.rwt.internal.service.SessionStoreImpl.valueUnbou nd(SessionStoreImpl.java:130)
org.mortbay.jetty.servlet.AbstractSessionManager$Session.unb indValue(AbstractSessionManager.java:923)
org.mortbay.jetty.servlet.AbstractSessionManager$Session.rem oveAttribute(AbstractSessionManager.java:843)
org.eclipse.equinox.http.servlet.internal.HttpSessionAdaptor .removeAttribute(HttpSessionAdaptor.java:87)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.cle arSession(LifeCycleServiceHandler.java:227)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.che ckRequest(LifeCycleServiceHandler.java:215)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:173)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:170)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:135)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.access$1(RWTLifeCycleServiceHandlerSync.java:1)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync$ServiceRunnable.run(RWTLifeCycleServiceHandlerSync.jav a:71)
at java.lang.Thread.run(Thread.java:613)
Cheers.
Roberto.
Frank Appel escribió:
> we are currently doing some internal work for performance and memory
> optimizations - maybe we did cause this problem. we will check that. Does
> the stacktrace ends at window.close or is there some more information about
> who is closing the window?
> Ciao
> Frank
> "Roberto Sá‡nchez" <roberto@autonomind.com> schrieb im Newsbeitrag
> news:fcmerf$66s$1@build.eclipse.org...
>> I'm using a class that extends from SessionSingletonBase, How can I remove
>> Regards.
>> Roberto.
FUDForum. Page generated in 0.04301 seconds
