Home » Eclipse Projects » Remote Application Platform (RAP) » Session Issues
Session Issues [message #47371] Mon, 17 September 2007 13:51 Go to next message
Hello, with latest changes about session behaviour, sometimes, when I
change between entrypoints this error appears on console (This problem
also occurs in DEMO App, changing between /tea and /rap servlets ):
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:704)
at org.eclipse.swt.SWT.error(SWT.java:650)
at org.eclipse.swt.SWT.error(SWT.java:646)
at org.eclipse.swt.widgets.Widget.error(Widget.java:725)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:557)
at org.eclipse.jface.window.Window.close(Window.java:321)
I'm not sure about what is the correct way to manage session, should I
invalidate it when workbench is closed ? how ?
I'm using a class that extends from SessionSingletonBase, How can I
remove it from SessionStore ?
Regards.
Roberto.
Re: Session Issues [message #47461 is a reply to message #47371] Tue, 18 September 2007 02:57 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
we are currently doing some internal work for performance and memory
optimizations - maybe we did cause this problem. we will check that. Does
the stacktrace ends at window.close or is there some more information about
who is closing the window?
Ciao
Frank
"Roberto S
Re: Session Issues [message #47521 is a reply to message #47461] Tue, 18 September 2007 03:17 Go to previous message
Hi Frank, this is the exact StackTrace, I got reproduce it when I call
/rap and then /rap=startup=controls:
org.eclipse.jface.window.ApplicationWindow.close(Application Window.java:287)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1512)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:610)
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:586)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:701)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:699)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:106)
at org.eclipse.ui.internal.Workbench$10.run(Workbench.java:830)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:8 27)
at org.eclipse.ui.internal.Workbench.access$6(Workbench.java:75 1)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1010 )
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1008)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:979)
at org.eclipse.ui.internal.Workbench$2.run(Workbench.java:93)
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 409)
org.eclipse.ui.internal.Workbench$ShutdownHandler.beforeDest roy(Workbench.java:97)
org.eclipse.rwt.internal.service.SessionStoreImpl.valueUnbou nd(SessionStoreImpl.java:130)
org.mortbay.jetty.servlet.AbstractSessionManager$Session.unb indValue(AbstractSessionManager.java:923)
org.mortbay.jetty.servlet.AbstractSessionManager$Session.rem oveAttribute(AbstractSessionManager.java:843)
org.eclipse.equinox.http.servlet.internal.HttpSessionAdaptor .removeAttribute(HttpSessionAdaptor.java:87)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.cle arSession(LifeCycleServiceHandler.java:227)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.che ckRequest(LifeCycleServiceHandler.java:215)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:173)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:170)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:135)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.access$1(RWTLifeCycleServiceHandlerSync.java:1)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync$ServiceRunnable.run(RWTLifeCycleServiceHandlerSync.jav a:71)
at java.lang.Thread.run(Thread.java:613)
Cheers.
Roberto.
Frank Appel escribió:
> Ciao
> Frank
> "Roberto Sá‡nchez" <roberto@autonomind.com> schrieb im Newsbeitrag
> news:fcmerf$66s$1@build.eclipse.org...
>> I'm using a class that extends from SessionSingletonBase, How can I remove
>> Regards.
>> Roberto.
Previous Topic:Updating a View in an other Session
Next Topic:FormEditor
Current Time: Fri Jul 18 00:20:52 EDT 2025
Powered by FUDForum. Page generated in 0.07572 seconds
