Home » Eclipse Projects » Plugin Development Environment (PDE) » IAE in Completion Proposal ("Signature.appendTypeSignature()"
IAE in Completion Proposal ("Signature.appendTypeSignature()" [message #47360] Tue, 17 February 2009 13:25 Go to next message
R3.4.1, WinXP
I don't see a newsgroup "eclipse.ide" or "... jdt" or the like, so I am
hoping this "platform.pde" is correct for this issue.
I have a class with (among others) two fields _reader and _resizer; in
an if-statement, I have "if (null ==_re|) {" and at the "|" is my
cursor; I press CTRL-Space, and instead of completions, I get the
callstack-below. I have not seen any bugs that seem to be this problem.
-Paul
Found a problem with the 'by relevance'
(org.eclipse.jdt.ui.RelevanceSorter) extension to the
"javaCompletionProposalSorters" extension point. The extension has
thrown a runtime exception.
java.lang.IllegalArgumentException
at org.eclipse.jdt.core.Signature.appendTypeSignature(Signature .java:2371)
at org.eclipse.jdt.core.Signature.appendTypeSignature(Signature .java:2278)
at org.eclipse.jdt.core.Signature.toCharArray(Signature.java:22 57)
at org.eclipse.jdt.core.Signature.toString(Signature.java:2734)
org.eclipse.jdt.internal.corext.template.java.SignatureUtil. stripSignatureToFQN(SignatureUtil.java:201)
org.eclipse.jdt.ui.text.java.JavaContentAssistInvocationCont ext.getRHSHistory(JavaContentAssistInvocationContext.java:18 9)
org.eclipse.jdt.ui.text.java.JavaContentAssistInvocationCont ext.getHistoryRelevance(JavaContentAssistInvocationContext.j ava:175)
org.eclipse.jdt.internal.ui.text.java.LazyJavaTypeCompletion Proposal.computeRelevance(LazyJavaTypeCompletionProposal.jav a:359)
org.eclipse.jdt.internal.ui.text.java.LazyJavaCompletionProp osal.getRelevance(LazyJavaCompletionProposal.java:370)
org.eclipse.jdt.ui.text.java.CompletionProposalComparator.ge tRelevance(CompletionProposalComparator.java:83)
org.eclipse.jdt.ui.text.java.CompletionProposalComparator.co mpare(CompletionProposalComparator.java:60)
org.eclipse.jdt.internal.ui.text.java.RelevanceSorter.compar e(RelevanceSorter.java:36)
org.eclipse.jdt.ui.text.java.AbstractProposalSorter.compare( AbstractProposalSorter.java:89)
at java.util.Arrays.mergeSort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at java.util.Collections.sort(Unknown Source)
org.eclipse.jdt.internal.ui.text.java.ProposalSorterHandle.s ortProposals(ProposalSorterHandle.java:192)
org.eclipse.jdt.internal.ui.text.java.JavaCompletionProcesso r.filterAndSortProposals(JavaCompletionProcessor.java:87)
org.eclipse.jdt.internal.ui.text.java.ContentAssistProcessor .computeCompletionProposals(ContentAssistProcessor.java:249)
org.eclipse.jface.text.contentassist.ContentAssistant.comput eCompletionProposals(ContentAssistant.java:1836)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .computeProposals(CompletionProposalPopup.java:553)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$16(CompletionProposalPopup.java:550)
org.eclipse.jface.text.contentassist.CompletionProposalPopup $2.run(CompletionProposalPopup.java:485)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(CompletionProposalPopup.java:479)
org.eclipse.jface.text.contentassist.ContentAssistant.showPo ssibleCompletions(ContentAssistant.java:1664)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor $AdaptedSourceViewer.doOperation(CompilationUnitEditor.java: 177)
org.eclipse.ui.texteditor.ContentAssistAction$1.run(ContentA ssistAction.java:82)
org.eclipse.ui.texteditor.ContentAssistAction.run(ContentAss istAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:185)
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:109)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:472)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:824)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:882)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:571)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:512)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:127)
Re: IAE in Completion Proposal ("Signature.appendTypeSignature()" [message #47392 is a reply to message #47360] Wed, 18 February 2009 09:58 Go to previous messageGo to next message
The newsgroup you want is eclipse.tools.jdt - I've copied it to this
response.
I think it would be easier if you provided a complete class that
demonstrates the problem.
On 2/17/2009 1:25 PM, Paul E. Keyser wrote:
> R3.4.1, WinXP
> -Paul
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: IAE in Completion Proposal ("Signature.appendTypeSignature()" [message #47422 is a reply to message #47392] Wed, 18 February 2009 11:58 Go to previous messageGo to next message
>> R3.4.1, WinXP
>> -Paul
>> at
>> at
Sure sounds like a bug. If this is reproducible, please report it in
Bugzilla (against the JDT component, Core subcomponent) including a code
example that causes it to happen.
Make sure to mention any third-party plug-ins that you have installed,
because plug-ins can contribute completion proposals and that may be causing
the problem.
Re: IAE in Completion Proposal ("Signature.appendTypeSignature()" [message #47512 is a reply to message #47422] Thu, 19 February 2009 06:22 Go to previous message
>>> R3.4.1, WinXP
>>> -Paul
>>> at
>>> at
> Bugzilla
Of course you can always first search whether the bug already got
reported ;-)
Looks like you see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=243023
Dani
> the problem.
Re: IAE in Completion Proposal ("Signature.appendTypeSignature()" [message #592118 is a reply to message #47360] Wed, 18 February 2009 09:58 Go to previous message
response.
> R3.4.1, WinXP
> -Paul
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: IAE in Completion Proposal ("Signature.appendTypeSignature()" [message #592131 is a reply to message #47392] Wed, 18 February 2009 11:58 Go to previous message
>> R3.4.1, WinXP
>> -Paul
>> at
>> at
the problem.
Re: IAE in Completion Proposal ("Signature.appendTypeSignature()" [message #592160 is a reply to message #47422] Thu, 19 February 2009 06:22 Go to previous message
>>> R3.4.1, WinXP
>>> -Paul
>>> at
>>> at
> Bugzilla
reported ;-)
Dani
> the problem.
Previous Topic:Is there possible to programmatically change the target platform of a workspace?
Next Topic:To test my plugin I need to remove the singleton
Current Time: Wed Jul 02 19:53:57 EDT 2025
Powered by FUDForum. Page generated in 0.04898 seconds
