Home » Modeling » GMF (Graphical Modeling Framework) » Exception in GMF
Exception in GMF [message #47345] Wed, 13 September 2006 15:17 Go to next message
Originally posted by: amoiln.sktcorp.com
I am using GMF 1.0 and Eclipse 3.2. I changed my ECORE model, and now I
have an exception whenever I try to select one of the properties in the
GMFMAP window.
Can anyone tell me what might be causing this and how I can work around
it? Any suggestions for how to debug a problem like this?
Thanks!
Arthur Molin
!ENTRY org.eclipse.ui 4 4 2006-09-13 14:14:04.115
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-09-13 14:14:04.135
!MESSAGE java.lang.ArrayStoreException
!STACK 0
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:188)
at org.eclipse.emf.ecore.util.EcoreEList.resolve(EcoreEList.jav a:156)
org.eclipse.emf.ecore.util.EObjectResolvingEList.resolve(EOb jectResolvingEList.java:58)
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
org.eclipse.emf.common.util.BasicEList$EIterator.next(BasicE List.java:1274)
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.collect ReachableObjectsOfType(ItemPropertyDescriptor.java:875)
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.collect ReachableObjectsOfType(ItemPropertyDescriptor.java:878)
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.collect ReachableObjectsOfType(ItemPropertyDescriptor.java:887)
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.getReac hableObjectsOfType(ItemPropertyDescriptor.java:829)
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.getComb oBoxObjects(ItemPropertyDescriptor.java:774)
org.eclipse.gmf.mappings.provider.NodeReferenceItemProvider$ 1.getComboBoxObjects(NodeReferenceItemProvider.java:88)
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.getChoi ceOfValues(ItemPropertyDescriptor.java:1410)
org.eclipse.emf.edit.ui.provider.PropertyDescriptor.createPr opertyEditor(PropertyDescriptor.java:402)
org.eclipse.ui.views.properties.PropertySheetEntry.getEditor (PropertySheetEntry.java:379)
org.eclipse.ui.views.properties.PropertySheetViewer.activate CellEditor(PropertySheetViewer.java:154)
org.eclipse.ui.views.properties.PropertySheetViewer.handleSe lect(PropertySheetViewer.java:702)
org.eclipse.ui.views.properties.PropertySheetViewer.access$7 (PropertySheetViewer.java:680)
org.eclipse.ui.views.properties.PropertySheetViewer$5.mouseD own(PropertySheetViewer.java:790)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Exception in GMF [message #47370 is a reply to message #47345] Wed, 13 September 2006 15:21 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
Did you regenerate the model and edit plugins?
> GMFMAP window.
> Thanks!
> Arthur Molin
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Exception in GMF [message #47550 is a reply to message #47370] Wed, 13 September 2006 19:02 Go to previous messageGo to next message
Yes, I did. What I did not do is update the GMFMAP file, because any
attempt to do so throws an exception, so the GMFMAP file refers to
structures that are not present in the ECORE file (or at least are moved
around in the hierarchy).
I also discovered that attempting the Validate the GMFMAP file throws a
bunch of exceptions:
!ENTRY org.eclipse.gmf.validate 4 300 2006-09-13 17:59:16.315
!MESSAGE Validation failed unexpectedly for 'Mapping'. See log for details.
!STACK 0
org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:439)
org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.next(EContentsEList.java:549)
org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.handleC rossReference(EcoreUtil.java:1565)
org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.crossRe ference(EcoreUtil.java:1541)
org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .findExternalCrossReferences(EcoreUtil.java:1775)
org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .find(EcoreUtil.java:1787)
org.eclipse.gmf.internal.validate.ExternModelImport.intializ eExternPackages(ExternModelImport.java:122)
org.eclipse.gmf.internal.validate.AbstractValidator.getExpre ssion(AbstractValidator.java:74)
org.eclipse.gmf.internal.validate.AbstractValidator.getExpre ssion(AbstractValidator.java:58)
org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleEAnnotation(AnnotatedOclValidator.java:1 27)
org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleMetaModel(AnnotatedOclValidator.java:175 )
org.eclipse.gmf.internal.validate.AnnotatedOclValidator.vali dateOCL(AnnotatedOclValidator.java:89)
org.eclipse.gmf.internal.validate.AnnotatedOclValidator.vali date(AnnotatedOclValidator.java:73)
org.eclipse.gmf.internal.validate.ValidatorChain.validate(Va lidatorChain.java:70)
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:127)
org.eclipse.emf.edit.ui.action.ValidateAction$3.validate(Val idateAction.java:226)
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:107)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:87)
org.eclipse.emf.edit.ui.action.ValidateAction.validate(Valid ateAction.java:233)
org.eclipse.emf.edit.ui.action.ValidateAction$1.run(Validate Action.java:147)
org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.ex ecute(WorkspaceModifyDelegatingOperation.java:68)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
!ENTRY org.eclipse.gmf.validate 4 300 2006-09-13 17:59:16.385
!MESSAGE Validation failed unexpectedly for 'Label Mapping'. See log for
details.
!STACK 0
org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryPr oxyResolves(EObjectValidator.java:330)
org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDe faultConstraint(EObjectValidator.java:183)
org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:168)
org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:142)
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:130)
org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:146)
!ENTRY org.eclipse.gmf.validate 4 220 2006-09-13 17:59:16.435
!MESSAGE Unexpected error during expression evalutation. See log for
details.
!STACK 0
org.eclipse.emf.ocl.expressions.impl.IterationTemplate.initi alizeIterators(IterationTemplate.java:108)
org.eclipse.emf.ocl.expressions.impl.IterationTemplate.evalu ate(IterationTemplate.java:71)
org.eclipse.emf.ocl.expressions.impl.EvaluationVisitorImpl.e valuateForAllIterator(EvaluationVisitorImpl.java:1533)
org.eclipse.emf.ocl.expressions.impl.EvaluationVisitorImpl.v isitIteratorExp(EvaluationVisitorImpl.java:1461)
org.eclipse.emf.ocl.expressions.impl.IteratorExpImpl.accept( IteratorExpImpl.java:60)
at org.eclipse.emf.ocl.query.impl.QueryImpl.evaluate(QueryImpl. java:224)
org.eclipse.gmf.internal.validate.ocl.OCLExpressionAdapter.d oEvaluate(OCLExpressionAdapter.java:117)
org.eclipse.gmf.internal.validate.expressions.AbstractExpres sion.evaluate(AbstractExpression.java:162)
org.eclipse.gmf.internal.validate.expressions.AbstractExpres sion.evaluate(AbstractExpression.java:147)
org.eclipse.gmf.internal.validate.ConstraintAdapter.doEvalua te(ConstraintAdapter.java:81)
org.eclipse.gmf.internal.validate.ConstraintAdapter.isSatisf ied(ConstraintAdapter.java:89)
org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleConstrainedElement(AnnotatedOclValidator .java:231)
org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleEAnnotation(AnnotatedOclValidator.java:1 34)
org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleMetaModel(AnnotatedOclValidator.java:190 )
!ENTRY org.eclipse.gmf.validate 4 300 2006-09-13 17:59:16.475
details.
!STACK 0
!ENTRY org.eclipse.gmf.validate 4 220 2006-09-13 17:59:16.525
details.
!STACK 0
java.lang.IllegalArgumentException: The name: (self) already has a
binding: (org.eclipse.gmf.mappings.impl.LabelMappingImpl@b77801
(readOnly: false, viewPattern: null, editPattern: ))
org.eclipse.emf.ocl.expressions.util.EvalEnvironment.add(Eva lEnvironment.java:83)
at org.eclipse.emf.ocl.query.impl.QueryImpl.evaluate(QueryImpl. java:223)
!ENTRY org.eclipse.gmf.validate 4 300 2006-09-13 17:59:16.575
details.
!STACK 0
!ENTRY org.eclipse.gmf.validate 4 220 2006-09-13 17:59:16.615
details.
!STACK 0
!ENTRY org.eclipse.gmf.validate 4 220 2006-09-13 17:59:16.665
details.
!STACK 0
Re: Exception in GMF [message #48033 is a reply to message #47550] Thu, 14 September 2006 10:55 Go to previous message
I'd suggest you to edit .gmfmap file manually and remove the property that
causes exception altogether.
Artem
"Arthur Molin" <amoiln@sktcorp.com> wrote in message
news:eea2pt$7i1$1@utils.eclipse.org...
> details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> details.
> !STACK 0
> binding: (org.eclipse.gmf.mappings.impl.LabelMappingImpl@b77801 (readOnly:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> details.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:How to add a GUI to the properties view
Next Topic:can domain model updates drive graphical definition model updates?
Current Time: Wed Nov 19 04:52:30 EST 2025
Powered by FUDForum. Page generated in 0.05095 seconds
